February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 07-25-2003, 02:47 AM
fxbill's Avatar
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Sorry....browser back double post..!
  #22 (permalink)
Old 06-11-2004, 01:24 AM
Cobra Make, Engine: 95 mustang cobra replica Carb. 351w/tremec/373
Send a message via AIM to HybridHorseplay
Hi i'm new here and this is my first post on the forum.
i've been reading all of the cam/ gear posts.
i have one question about the steel gear and comp cam.
if the cast gear on the msd dist disinigrated with the nodular cast cam, then the cam was harder. so if you are now using a steel gear with the hardened cam, isn't there a chance that the dist gear will eat up the cam gear ??? i know you have pulled the dist to check it, but has anyone gone back and checked the cam gear for excessive wear? It is 330 in the morning here so i might be on a tangent...lol
I am putting a motor together for a mustang that i am going to drive while i build the 427 for my 95 cobra replica.
It is a 1970 302 30 over stock bottom end.
with 1990 e-7 heads and stock 90 efi.
here is my problem...
i have installed a non roller comp cam # 35-239-3
it uses a 351w firing order for efi on a non roller block...
jegs and comp cam suggested a cast gear.
I am using a stock 302 efi (module) dist.
it came with a steel gear as the donor was a roller motor.
i purchased a cast gear for 16 bucks from advance auto parts.
which should be used?
if the comp cam is extra hard as you stated then i should use the steel.
if the aftermarket advance cast gear is hardened i should be ok...
HELP, i am supposed to take the dist to the machine shop in the morning and change the gear so i can drop in the dist on sat.
thanks Aaron in S.C.
  #23 (permalink)
Old 06-11-2004, 08:51 AM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Update on my 514
The cam was the Crane unit which comes with the 514 from Ford Performance. The distributor was stock. High volume oil pump/80 PSI/20-50 Valvoline...Now, I don't know exactly what metals these two gears are made of, but I DO know when removed for rebuild they both looked new. We re-used both with confidence. Have been told that the MSD distributor gear IS the problem. SO... why not do like I do, and use the slightly ugly stock distributor (I painted it) with all MSD electonics? Solves the problem.. I have an MSD cap/wires/etc to pretty up the situation, as soon as I get her back on the road next week.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
