February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 07-30-2003, 08:33 AM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Default PCV for 351W
Hi Guys,
I'm using a 1969 351W and would like to know what you guys have found to be the best way to vent the crankcase. The breather cap I am using has a short pipe fitting for a vent hose. Should I place the PCV Valve between that breather fitting and the air filter or should I go for Carb vacuum or manifold vacuum?
I am using a Raod Demon carb and there is a vacuum pipe at the rear base of the carb. I also have a threaded port for a vacuum fitting on the rear portion of the Edelbrock Performer RPM manifold.
Any ideas, advice, or suggestions, as always will be greatly appreciated.
Tony
Old 07-30-2003, 10:37 AM
Ron61's Avatar
Post
Tony,
On my stroker I have a regular PCV valve coming out of the right hand valve cover and the hose connects to the vacuum intake in the plate below the carb. On the left hand side I just have a hose from the breather cap to the air cleaner and it has worked since 1996.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-30-2003, 11:05 AM
Roscoe's Avatar
Tony,
I've got a Billet Specialties PCV valve holder with a tube going to the inlet on the Speed Demon.
Roscoe
Roscoe
Old 07-30-2003, 02:02 PM
TonyMadrid's Avatar
Default PCV connection
I have Edelbrock Signature Valve covers and there is no grommet on the valve cover to accept a pcv vale. There is a breather cap with a hose pipe attached.
How would I run a PCV valve? Would I run it from that breather cap pipe to the carb, Air filter, or should I place a fitting in the manifold to accept it?
Tony
P.S. I am buying tall Cobra Valve covers and air claener in the near future. Bought the Edelbrocks because the price was right.
