January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 07-05-2004, 08:05 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Send them to me at my other email
brucete@earthlink.net
Send me one or two at a time so you do not over load my mail box.
Just send me a shot of the front of it and I should be able to tell you what family the block is.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
  #22 (permalink)
Old 07-05-2004, 12:52 PM
Sent you an email but wanted to follow up here as well. It looks like you have a 460 HD truck block from around 1988-1990.
Bruce Edwards
  #23 (permalink)
Old 07-05-2004, 04:56 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Hey Bruce, sent you a shot of the valve train if that helps.
I did measure the crank snout, it looks like it is 1 and 3/8" in diameter.
While removing one of the valve covers, it looks like someone had written in marker at one time "7.5 FA".
I would/should/could take this as 7.5 liters, which would be 460ci.
BUT, is there any other big block that would share the same size valve covers? Like maybe a 429ci?
Anyone........
I'm not busy because I did it right the third time . . .I think!
  #24 (permalink)
Old 07-05-2004, 05:05 PM
Yes the 429 uses the same covers but the number on the heads shows it as a 460. I guess it could be a 429 with 460 heads. Only way to know for sure is to pull the heads and measure the bore.
Bruce Edwards
