November 2024
Old 12-10-2004, 08:00 PM
Cobra Make, Engine: venom cobra 302
Default 302 345hp crate motor
Ihave a venom cobra with a gt40 302 345hp motor with about 800 miles on it the motor sounds like a sewing machine called ford tech line they said its nomal anybody else have this problem
thanks soph
Old 12-10-2004, 08:03 PM
Send a message via MSN to CowtownCobra
What kind of a sewing machine?
Old 12-10-2004, 08:25 PM
singer
Old 12-10-2004, 10:15 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Probably just still tight.....Put another 1000 miles on it and check it then.
Tim
" It ain't no big deal"
Old 12-11-2004, 06:39 AM
69 Mach I's Avatar
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
I suspect the noise is coming from your roller rockers.
Old 12-19-2004, 10:06 PM
That motor does not come with Roller Rockers unless they were put on before install??
Old 12-20-2004, 07:50 AM
brian whats up give me a call 1845 425 4386
Old 12-21-2004, 05:51 PM
Cobra Make, Engine: Venom 351W
Send a message via AIM to joeg
HI Brain. Nice to see you on-line again.
joe
Old 01-02-2005, 06:24 PM
Cobra Make, Engine: 68 GT 500 convt, 428 Cobra Jet
Wink Motor Noise
Hey;
A sewing machine sounds better than a tractor.
Old 01-02-2005, 08:25 PM
lovehamr's Avatar
Stolen Avitar
It sounds as though your mufflers may be to quiet! LOL
Old 01-04-2005, 09:09 AM
Talking Noise ?
What mufflers ?
Old 01-08-2005, 02:03 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Exclamation Dist gear
Hi,
I assume you are running a carb and not EFI.
The roller cam in the engine needs a steel cam gear on your distributor shaft, so you need to make sure it has one or it will get eaten away and destroy you engine. Msd distributors can have a brass gear and is too soft for long use, Ford motorsports sells a gear and any machine shop could install it on the shaft.
Good Luck,
Perry.
Old 01-08-2005, 04:32 PM
I have a steel gear
Old 01-08-2005, 05:15 PM
Arrow noise
Hi,
Ok, not the gear.
If you have a 5 speed standard trans it could be the throw out bearing whirring around,may be defective and need to be changed.
Perry.
Old 01-08-2005, 06:12 PM
sounds like a tapping from both sides ford claims its normal rockers are al tight
Old 01-08-2005, 10:20 PM
Sounds like you need to re-adjust your valves.
Old 01-28-2005, 04:58 PM
they are non adjustable
