1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
07-04-2006, 11:37 AM
MD
Cobra Make, Engine: Unique, 427SO, it runs
I too have trouble getting the oil temps high enough with the cooler on a 427SO.
I took a piece of cardboard cut to the exact size of the oiler cooler, fiberglassed over it, with under $10 worth of materials from any marine supply store, painted it black, and attach and remove it with velcro to the front of the cooler.
It's ridiculously simple and works great.
Clay
07-04-2006, 12:02 PM
GA
Originally Posted by Mark Husar
Perhaps you guys could educate me a little. What would the acceptable oil temperature during normal driving? As the oil heats up, where would the upper limits of temperature be and when should I be concerned that it is getting hot to the point of damage?
My 396 stroker runs water temp right at 185 degrees and my oil temperature stays about 200 degrees. When I run it hard, the oil temp will creep up to 225 or so. Occasionally I have seen 240. I have the canton, but don't run a cooler at this point. Should I re-connect the cooler ? The temps here in Sac. run 100 degrees + in summer.
Any advice would be appreciated.
I would want to see 220F during normal driving - hard use (sustained 100 mph or track use I would think 240-260....upper limit? 320......
07-04-2006, 12:54 PM
ca
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Well Hi Pat.
That jives with what I've been told: 100 degrees C, normal driving; 120 degrees C spirited, and 135 degrees C as a safe upper limit.
Dave
08-01-2006, 12:27 PM
MI
Has anyone here used an Earl's oil cooler? Any thought?
08-01-2006, 01:00 PM
IL
Cobra Make, Engine: Everett-Morrison, 434 cid
I have... identical to a Mocal... you'd almost think they are manufactured by the same company.
08-02-2006, 06:48 AM
MI
What is the typical size used?
08-02-2006, 07:10 AM
IL
Mocal 235 Matrix 16 row w/-10 fittings is the size that Cobra Accessories sells. I got the same size with -12 fittings from Earls.
08-02-2006, 07:27 AM
MI
Thanks Scott.
08-02-2006, 08:06 AM
WI
Cobra Make, Engine: Superformance MkIII, Performance Engineering 418 Stroker. Keyless Entry, and naturally aspirated A/C
Ok, so far I'm following the logic of the oil temps.
Here is my problem. My oil cooler is not even connected, and I can't get the oil over 190 even on a 100 degree day. Engine temps never exceed 196, so maybe I need a warmer thermostat ?
FYI, I have a 418 stroker with a canton 8qt pan. Maybe that huge pan bleeds off too much heat ?
At least I can sleep at night knowing my car won't overheat if I get stuck in traffic.
If love is blind, then why do I love women's lingerie so much ?
08-02-2006, 08:29 AM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Remod:
You worry too much.
bob
08-02-2006, 08:38 AM
WI
Thanks Bob,
Life was great. Birds chirping, harps and zithers, angels choirs, and then somebody informed me about my low oil temps!
Now I'm looking for a box cutter to slit my wrists..
But Bob intervened in the nick of time!
08-02-2006, 09:35 AM
PA
I was running my car REALLY hard the other day and got the oil temp up to 275-280ish. So, I called my engine man. He said "No Worries". He did say that if I hit 300+ regularly it is time to hook up the cooler.
Apparently cold oil is worse that hot oil.
08-02-2006, 10:47 AM
JBCOBRA, yes!! I amazed with how hot the oil temps can climb if you keep the engine revs up. For me, a quick burst here and there doesn't do much...but if I maintain revs ...say above 3500-4000rpm...I need to keep an eye out on the oil temp becuase it climbs with no signs of stopping. I either change my driving, to keep the revs lower, or turn on the oil cooler.
I've never noticed this with other cars or engines. Is it just me, or just a Windsor thing...or is it because my SPF is the only car that I've ever had with an oil temp gage...?
08-02-2006, 03:10 PM
PA
Oil temp gauges definately come in handy. I know they have saved me $$$ on a variety of cars. Basically, run the heck out it. Just never beat them when they are not fully warmed up. I think that is the worst thing for an engine. I look at that guage more during warmup/putting around.........waiting patiently before I PUT IT TO THE WOOD! LOL
