January 2025
26 27 28 29 30 31
Old 05-20-2007, 02:18 PM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Default shaft rockers or stud mount?
What are the pro/cons of a T&D Shaft rocker set up? I already own Comp Cams magnum stud mount rockers, but I am beginning to think the shaft rockers will be more reliable. Is that the case?
Old 05-20-2007, 03:06 PM
Rick Parker's Avatar
Stud mount rockers have been the norm for SBF since its inception with the exception of sled type rocker that bolted down and were non adjustable. You may want to check your rocker geometry and pushrod length as a remedy to your interferance beween the rocker and the stud. As far as benefits or reliability one VS the other, the shaft mounted once properly set up will have less deflection, especially if you are using very heavy springs. The current shaft rockers for all but the FE's were developed for Winston Cup and have filtered down from there. It allowed for increased RPMs (they are near 9300 RPM now) in unrestricted form, with a non roller cam. These guys are THE cutting edge in push rod V8 technology.
For a hydraulic or solid roller, shaft mounted rockers will have more stability, for flat tappet (solid or hydraulic) 3/8" or 7/16" diameter studs (high quality IE:ARP) will work just fine. If you use studs, try to have the majority of the threads above the fulcrum of the rocker, so the rocker is supported on the stud without contacting on the threads.
Rick
