December 2024
Old 10-25-2008, 06:02 AM
Default steel braided lines
I want to change the stock hoses and use steel braided lines.Where can I get them? thanks.
Old 10-25-2008, 06:08 AM
Summit Racing has both Russell and Earl's steel braided lines; both DOT approved. Earl's also has a line of "Speed-Flex" hoses that are extruded Teflon, just in case that master cylinder goes awry and pumps up your lines to 4,000 PSI.
Old 10-25-2008, 09:15 AM
Cobra Make, Engine: jbl
you might consider starlite from aeroquip. easy to work with and lots cheaper with kevlar outer braid. don't have the name now but there is place in nc where i was buying -12 hose for $8 a foot. uses reg. fittings. if interested i can get the name later today.
