March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 09-16-2009, 02:26 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Default Milodon oil pans and gaskets
Does anyone know if the Milodon pans require the use of the Milodon gasket. I had one before and never a problem with oil dripping. Now I don't have one but instead have a stock gasket and it seems to leak a bit. the difference being the stock gasket is 4 pieces and cork. The Milodon was a 1 piece and rubber.
Old 09-16-2009, 02:31 PM
Don't know if it helps you but I have Milodon gaskets on an FE and like them better than FelPro composite. It's a quality gasket.
Chas.
Old 09-16-2009, 02:32 PM
Banned
I personally have had success with the Felpro 1810 (two piece rubber impregnated pan seals with individual rubber end seals), with Black Permatex Ultra. I also put a small smear on the pan rail side for insurance and (knock on wood) never a leak. I suppose these are considered composite gaskets because they are not 100% rubber nor 100% cork. But they work well.
-Dean
Old 09-16-2009, 02:41 PM
I may just go out and buy another milodon gasket but I have a hard time with the crazy price they get for it.
Old 09-16-2009, 02:47 PM
Banned
I've had my pan off three times in the last 18 months...trust me, I can now do this with my eyes closed. Felpro makes a good pan gasket.
EDIT: That reads weird...great gasket yet I removed my pan so many times.
1. Replaced crank and rod bearings when oil pressure started to dip
2. Failed fuel pump eccentric...#$&@#* major PITA for a $2.00 dowel pin
3. oil pan cracks needed rewelding
Old 09-16-2009, 03:10 PM
Rick Parker's Avatar
I previously had a Milodon Pan and used McCord High performance gaskets which had a metal washer at each stud hole intended to prevent the gasket from being compressed too thin. I never had any leakage. I late swiched to a one piece gasket that had a similar washer at each hole. I think it was made by Victor, or maybe Felpro, again...no leaks.
Rick
Old 09-16-2009, 03:21 PM
Wish somebody made FE gaskets like that. Is McCord still in business or bought up by somebody? Cometic? Detroit Gasket?
Chas.
Old 09-20-2009, 10:51 PM
Default 1 piece pan gasket
http://www.federalmogul.com/en/After...ormanceOilPan/
Rick
Old 09-21-2009, 05:47 AM
Yes Rick, I have experience with these Felcoid typre gaskets in GM apps and they work very well. I believe they make sets for Windsor/ Cleveland apps but not FE.
I think it's because FE's are one piece and SBF's are four piece gaskets.
Chas.
