January 2025
26 27 28 29 30 31
Old 04-08-2010, 04:05 PM
Randy M.'s Avatar
Cobra Make, Engine: SPF 2535 Indigo with White Stripes and Roush 427 SR
Default Replacing Parking Brake Pads
Does anybody have any tricks on replacing parking break pads. They are the drive shaft ones. I can get one side out and changed, but the one that is closest to the transmission doesn't want to come out. I can't seem to get enough clearance between the pad holder and the disc. I don't want to take all the support brackets and drive shaft out. I have otherwise disassembled it, but can't get enough space.
Thanks
Old 04-08-2010, 10:48 PM
Cobra Make, Engine: SPF, 418 Stroker
Hmmm... don't recall exactly how I did it, but I was able to replace the pads without removing the brake assy or the drive shaft. As best I remember, I had to loosen every nut/bolt on the brake assembly to get enough clearance to r/r the pads. So I suppose this is mostly moral support - keep trying, it can be done.
Be sure to readjust the parking brake once the new pads are in. It's a fairly tricky process, which is detailed in a procedure in the SCOF tech library. Follow it exactly and you'll be happy.
Jerry
SPO 2038
Old 04-09-2010, 03:41 PM
Randy M.'s Avatar
Thanks. I'll keep working at it. Worst case would be to just use 2nd or 3rd gear and park on level ground. That is what I have been doing but thought that since car was up on stands for routine maintenance then I would address this issue. Not making much headway though.
