March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
  #21 (permalink)
Old 06-04-2010, 04:50 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
I used an M12 about 5" long ( whatever that is in metric). I used a flat washer at each end with an oblong lock nut. Not the crappy nylon lock nut!
Scott
  #22 (permalink)
Old 10-21-2010, 07:22 AM
Cobra Make, Engine: Superformance, 427R, SPO2561
What is the length of the new longer bolt?
  #23 (permalink)
Old 10-21-2010, 10:23 PM
scootter's Avatar
It it a M12 1.75 pitch 150mm long. It is 6" long with a 4 1/2 shoulder so it goes all the way through the bracket.
http://www.mcmaster.com/#cap-screws/=9dpbuq 91280A749 this is the part number. the link doesn't go to the right spot.
Scott
  #24 (permalink)
Old 10-22-2010, 08:17 AM
Jerry Clayton's Avatar
How about a pic of the broken bolt from the fractured end and also the broken end( if you have it)
  #25 (permalink)
Old 10-22-2010, 11:21 AM
scootter's Avatar
There are pics on the first page. I held the broken one up by the bracket so you can tell were it broke in relation to the bracket, and also were the new bolt would come out to.
Let me know if those work for you. I have more pics.
  #26 (permalink)
Old 10-22-2010, 12:43 PM
No---I want to see the end of the bolt for the fracture pattern
  #27 (permalink)
Old 10-22-2010, 01:08 PM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
You need to be using a close-tolerance NAS Shear-Bolt in this application. They are available from Pegasus Racing and maybe McMaster-Carr among other places. They can be obtained with lock-wire holes in the head and you can get lock-wire nuts for them... I would just use some loctite red, but your choice.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
  #28 (permalink)
Old 10-22-2010, 01:35 PM
scootter's Avatar
This is the best I have. Not sure if I threw the bolt away or not.
  #29 (permalink)
Old 10-22-2010, 01:43 PM
your bolt broke from overstressing the last thread probably from over tightening and the bolt being at the last thread(too long) not shear!!!
This part does not even need a bolt, a trailer hitch receiver pin with a hairpin would do the job just fine. You are overtightening a fastner trying to collapse two members of a very stout piece which only needs the center tube snugged up----
  #30 (permalink)
Old 10-22-2010, 01:51 PM
scootter's Avatar
Not exactly sure what you mean by to long? The original bolt only had a nut and washer on it. The threads stopped inside the center bushing.
Scott
  #31 (permalink)
Old 10-22-2010, 01:57 PM
what I mean is that the bolt was over tightened which will cause it to break at the last thread----
Yoi do not need a overly tight bolt there---bolt tightness will only maybe keep the bolt in place
A pin such as the pin in a Reese receiver type trailer hitch with a hairpin clip will do everything you need in that location
You do not need a bolt---even a piece of thin wall tubing will do if you want to save weight for racing
