March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 05-27-2010, 09:57 AM
Default over heating, fans not coming on!
my brothers car started to over heat due to the cooling fans not turning on, he has an older car with out the over ride switch on the dash... what would be the first steps in tracking down the problem? where to look first? fuses / relays/ wiring?
any info would be great
thank you
Old 05-27-2010, 10:58 AM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
One of the two fans stopped working on my car. Swapped the relay from the good fan to the bad, and it started working again. Replaced both relays to be safe.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 05-27-2010, 11:08 AM
where are the relays located?
Silverback51's Avatar
I had a fan stop and it was just a loose wire. It was still in place, just not far enough in to be engaged.
John Hall
Old 05-27-2010, 11:56 AM
Archrms's Avatar
The relays should be located under the dash to the left of the steering column.
Old 05-27-2010, 12:00 PM
Got the Bug's Avatar
Same thing happened to me. I pushed it back on and haven't had any problems since.
Doug
Old 05-27-2010, 12:02 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Older cars have only one fan relay...what is his car number?
Has he replaced his relay?
Can he make both fans work with a jumper across the temp switch on the lower left side if the radiator?
Do this first to isolate the problem.
SPFWiringDiagrams@Comcast.net
Old 05-27-2010, 12:17 PM
Cobra Make, Engine: spf 2112 *427 stroker windsor
i think his car # is 385
Old 05-27-2010, 02:30 PM
Have him put his hand close to the radiator after warming up the car and feel for heat. If hot, then he has a fan problem. If cool, then he has a thermostat problem.
Jim
Old 05-27-2010, 02:42 PM
SunDude's Avatar
pretty sure it's #1398 - UPDATE: turns out that I'm mistaken about this; don't know where I got my (mis)info...
Old 05-29-2010, 11:45 AM
PANAVIA's Avatar
The relays in these things run hot for the fans.
-- so a periodic replacement is not out of the question.
Steve
Old 05-29-2010, 12:13 PM
CobraEd's Avatar
Steve
if they are 30 amp, you can replace them with 50 amp.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
Old 05-30-2010, 08:15 PM
PANAVIA's Avatar
There are 70A aircon relays as well, but then I would wonder about the capability of the wire to transport the amps.
40a each would be my comfort level, the other considersation would be the fans themselves. Are the fan motors aged, corroded or damaged in such a way where they take more juice to operate ?
If they don't spin freely by hand you may have a fan motor issue
Steve
