January 2025
26 27 28 29 30 31
Old 06-13-2010, 02:35 PM
Paul Williams's Avatar
Cobra Make, Engine: Want A SPF
Default Superformance
Could anyone tell me if the Superformance cars are equiped with a external voltaged regulator.
Old 06-13-2010, 03:01 PM
yes it does
Old 06-13-2010, 05:36 PM
Cobra Make, Engine: Superformance aluminum427
mine is on the inner fender well right above the alternator.
Old 06-13-2010, 05:56 PM
Senile Club Cobra Member
They come with a standard Ford/Motorcraft regulator. If you run an internal regulator alternator you take the external unit out of the circuit.
The SPF also comes with a Duraspark ignition module that you eliminate if running an MSD type system.
They make it easy either way you want to go.
rick@autoventureusa.net
Old 06-13-2010, 09:52 PM
timsullivan's Avatar
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Default MSD Distributor works fine with Superformance Duraspark ignition module
Its not necessary to eliminate the Duraspark module as they are fully compatible with the MSD distributor. I used the MSD Pro-Billet Small Diameter Street Ford Distributor PN 9478 for my 351W based 408 stroker motor and spliced the two wire MSD distributor connection into the existing Superformance wiring 2 wire harness for the distributor and it works fine. No MSD ignition module needed and the MSD distributor is fully compatible with the Superformance factory installed Ford Duraspark ignition module that comes pre-mounted in the passenger footwell.
Old 06-14-2010, 05:15 AM
You are right of course, I meant if you run a full MSD module system in lieu of the Duraspark. Poibt is, the SPF supports most any of the options available.
