March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 05-13-2012, 02:42 PM
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Default Superformance speedometer gear?
Any Superformance owner can tell me the correct or tooth count for the speedometer drive gear so my gauge will read accurate? Currently reading slow. Rear tires size are the standard 275R6015. Tranny is the TKO 600 4617 and rear gear is 3:46. Thanks in advance!
Old 05-13-2012, 03:36 PM
Cobra Make, Engine: Superformance #522
Drive gear teeth X Axel ratio X Tire rev per mile
Divide the product by 1000 to obtain required drive gear teeth.
Old 05-13-2012, 05:49 PM
Smith speedo requires 19 teeth / pink tip. Remember it ain't electronic, it will be on around 60 mph but a little slower or faster below and after.
Old 05-13-2012, 06:09 PM
Senile Club Cobra Member
Ford part number C0DZ-17271-B. It is 19 tooth and pink. Available from your Ford dealer or most any Mustang parts vendor.
rick@autoventureusa.net
Old 05-13-2012, 07:23 PM
Thanks guys...a local Superformance owner confirmed the pink as you have indicated. I currently have the red gear. Thanks again!!
Old 05-13-2012, 07:25 PM
and thanks for the part number!!
