February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 10-22-2013, 09:45 AM
Cobra Make, Engine: year 2000 SPF 351
Default Differential cover,bolt torque
Hi, could someone tell me what the bolts get torque to for the differential cover. Superformance 8.8 aluminum center section thank you for your help. Michael
Old 10-22-2013, 12:12 PM
LMH's Avatar
LMH LMH is offline
Ford spec is 24 FT-LBS for an aluminum case. I'd guess SPF is the same.
Alba gu brąth
Old 10-22-2013, 12:37 PM
Karl Bebout's Avatar
A thumb and two fingers on a 1/4" ratchet will get them tight enough.
Karlos
Old 10-22-2013, 01:26 PM
Senile Club Cobra Member
Tighten them 'til they strip and then back them off a half turn.
24 Lb Ft as stated. You can confirm with a Ford dealer if you wish.
rick@autoventureusa.net
Old 10-23-2013, 08:33 AM
Thank you for your help. Micahel
