February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 11-10-2018, 06:47 PM
Default Ammeter reading +15amps running
Gauge reads Zero when ignition is off, fans take it down like they should but not as far as usual, system voltage 12.4 off, ~13.8 running, all connections on ign switch good, batt connections tight, optima red top battery couple years old..
Almost like the null has moved when running? The farthest down I can get it with ALL loads idling at about 950 is about +7 amps...
Battery cranks it right up.
Anyone had similar issue?
Superformance 1764
Built 427W
Aiken SC USA
Old 11-10-2018, 06:53 PM
Sometimes it's best not to "overthink" these things. Assuming this is a new symptom that has just arisen out of nowhere, try temporarily swapping in another battery, say from your daily driver, and see if you have the same readings.
