January 2025
26 27 28 29 30 31
Old 10-29-2006, 06:03 PM
Banned
Default The day is coming, I need advice. . .
I'm going to test drive my own Superformance around November 11. What do I look for in the test drive?
Old 10-29-2006, 06:17 PM
Cobra Make, Engine: Superformance #1683, Roush 392
Your wallet and/or checkbook. Congratulations in advance on your new purchase.
Old 10-29-2006, 06:27 PM
Cobra Make, Engine: SPF 1421
New or used? Looks new by your link. Not much, just fit and finish, door jambs, etc. Also ask about any squeeks, especially in the rear. The real item for potential to break is the engine. Take a good hard look at it, but again if everything is brand new....not really sure how much you should expect things to be 'out of sort'.
Joe S.-LI Lake Grove
Old 10-29-2006, 06:28 PM
wtm442's Avatar
Beam Me Up Scottie
Exclamation
There really is not much you can really check with a quick test drive, other than obvious defects. Find out what is the best method to contact anyone at the Reps business (via phone, fax or e-mail).
Get to know everyone in that company and what they do ... and can do for you if you have a problem.
Look over the paint to see if any chips or marks anywhere. Did you have them install the 3 M protector film? If not, why not?
Watch out for the pedal spacing ... it is very close. You WILL step on the brake a few times when you are trying to depress the clutch ... therefore, make sure you put on the 4 point harness, rather than just the lap belt.
Get an Owners Manual and read it 3 or 4 times when you get home.
Be extremely careful when putting the license plate on the car. Make sure you use very short bolts ... you do not want to scratch the paint, do you?
Congrats on your wise purchase ... and have fun. I know I do.
Warren
Old 10-29-2006, 06:44 PM
Jim Kellogg's Avatar
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Send a message via Yahoo to Jim Kellogg
Have your dealer go over/inspect the car with you front front to back. If you will be doing some/all of your own maintenance, have them show you the items that should be checked/adjusted on a regular basis.
Set up another day to come back with the car (1 or 2 weeks after delivery, or as soon as you get at least 500 miles on it) and have them recheck the car (driveshaft bolt torque, header bolts, suspension, ect).
Have them show you how to install the top and side curtains, even if you will 'never' use them!!!
Check out the 'Second Strike' website for Superformance owners and register (if you already haven't done so)
http://www.secondstrike.com
You may also wish to join SCOF (again, if you already haven't done so)
http://performanceunlimited.com/scof/subscribe.html
Both the above are excellent sources of info for Superformance owners, in addition to Club Cobra.
Be prepared for some excitement when you mash the 'go' pedal!!! Make sure you are pointed the direction you want to go :-)
Enjoy, and be careful,
Jim Kellogg
Breesport, NY
Old 10-29-2006, 07:00 PM
Banned
Thanks everyone! I have been working with Eric from Performance Engineering and Shane from Dynamic for 7+ months, so I'm comfortable with them. It's all brand new and will have a Shelby aluminum FE (527) tamed to 6~630HP and 685ft-lbs, but I will know more after the dyno pull this week. I do plan to use the top and read the manual and do 99% of my own work, I installed a lift and a heater in my garage, so I'm looking forward to it. I know I'll do some things this winter. . .
Old 10-30-2006, 06:05 AM
What type of lift did you install? I want to install one in my garage as well and don't really know where to start...
Old 10-30-2006, 06:34 AM
Banned
I wanted a two post lift for "low" ceilings and with a clear floor (no bar across to drive over) I also did not want the type with the troublesome nylon sliding blocks in the towers, because they can wear quicly and also jam. So I went with the Mohawk A7 wich is very heavy duty, has all steel bearings is American made and considered to be the best in the idustry. I am very happy with it. This is it: http://www.mohawklifts.com/consumer/a7.php
