February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 04-14-2007, 10:52 AM
Threebrand's Avatar
Cobra Make, Engine: Kirkham brushed, no stripes. BBM iron block by Blair Patrick
Default Inner fender rock proctection?
I am new to the group with SPF258, a roadster sporting a Southern Performance 427 bored and stroked to 484. Car is immaculate and I would like to keep it that way. I am concerned about tire thrown rocks hitting the inside of the fenders and causing paint damage to the exterior fender areas. Does anybody have a recommendation for a fix for this?
Old 04-14-2007, 11:25 AM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
There are probably several ways to accomplish this, however SPF started lining the inner fenders of the later cars and you can probably get them pre-cut from SPF and fit them right in.
WDZ
Old 04-14-2007, 11:54 AM
double ugly's Avatar
3M makes a product called chip guard in a rattle can but there are lots of products out there that may be better (cheaper) for the application. You could try this.
http://store.newlevelmotorsports.com/sponun.html
John
double ugly
Old 04-14-2007, 12:01 PM
There are several products that a lot of cobra owners have used, one of them being a "bedliner" product that is either sprayed, rolled, or brushed on. It is used to protect pickup truck beds against dings and dents, and is very effective as an undercoating application to protect against inner fender damage. RD
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
You need more than paint. I would think a high density foam would be the way to go.
Bob
Old 04-14-2007, 12:34 PM
It isn't paint. It's a fairly thick rubberized coating that insulates the fiberglass. I would use the brush on type rather that the spray on. I'm too nervous using rattle cans near a nice paint job.
John
double ugly
Old 04-14-2007, 01:08 PM
It is definitely NOT paint. You either roll or brush on a couple of coats and you have something that is 1/8 inch thick, or even more. This will take a lot of abuse that will never contact your fibreglass fender.
Old 04-14-2007, 02:02 PM
jwd's Avatar
jwd jwd is offline
Another vote for the brush on bedliner. That stuff is bullet-proof.
Old 04-14-2007, 02:15 PM
...boy am I glad I got a few scratches on mine, it would drive me nuts trying to keep it 'perfect'.
Old 04-14-2007, 02:31 PM
Cobra Make, Engine: spf, stroked 460
there is gentleman here in LA that owns 2 original cobras. One of his cars
had the high density foam in small part of the undercarriage. Next time I see him i'll ask where he got it from. I am too interested in putting something in there, because I want to run my 17's with the sticky nitto's.
Old 04-14-2007, 04:16 PM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
McMaster-Carr has some adhesive backed ¼ in. foam that I lined the inside of my fenders with.
It’ll cost you about $25 delivered.
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 04-14-2007, 04:22 PM
Cobra Make, Engine: SPF #1019
Craig Hill has pre-cut fender liners made of high density foam for SPFs. You can reach him @ (925) 449-3330.
Old 04-14-2007, 08:50 PM
Threebrand's Avatar
Good stuff guys. Thanks for the advice.
Old 04-14-2007, 09:38 PM
Banned
Scratches are the least of most peoples' worries. Fling a big stone and star crack the 'glass/paint...that will drive you nuts. Of course, the Kirkham guys are at this thread...
Old 04-14-2007, 10:44 PM
ST, do you know the product number for the adhessive stuff from mcmaster's. THANKS
Old 04-15-2007, 03:56 AM
ST's Avatar
ST ST is offline
The number is... 8722K44
Old 04-15-2007, 07:41 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I think this is going to come around to how much driving are you going to do.
If it is wonderful and looks great, you will have a problem with driving it too many places as...you will get rock, junk and crud thrown at the car.
I have Rhino hide covering the bottom part of the car's body. Would I do it again, YES. My car is driven a lot in the summer. The Rhino hide doesn't look smooth and finshed as much as it protects the surface from abuse.
So, if you coat with a "bed liner" it may not look as nice as a finished inner fender.
Just my $0.03
Old 04-15-2007, 09:07 AM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
I used sound-deadening material like Dynamat acailable in sheets or rolls from Jegs and others. Clean fender insides thoroughly with rubbing alcohol before application. Then, spray the edges and other areas liberally with rubberized undercoating
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 04-15-2007, 03:24 PM
Threebrand's Avatar
Jay, Dynamat in an exposed area. Interesting. Would you then seal it off with the brush on rhino lining or some other similar product to keep it intact and attached?
Old 04-15-2007, 05:50 PM
JCoop's Avatar
After I got a star crack in one fender on my previous SPF, I immediately lined the fenders on the new BB SPF and my GT40 as well. I used the Dynamat because I had left over material after lining everything in the GT40 as a sound-deadening project. The material has a peel off liner and a good adhesive. Surface has to be really clean, though. I didn't seal on top of it, just around the edges; with rubberized undercoating spray. I think it actually deadens road noise.
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
