January 2025
26 27 28 29 30 31
LinkBack Thread Tools Rating: Thread Rating: 103 votes, 4.87 average. Display Modes
  #121 (permalink)
Old 11-07-2008, 04:10 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Eric,
Well done!! Looks like my question about Dynatek working on my car's been answered. Rodney, you going to be ready after the first of year......with the twofer deal?
  #122 (permalink)
Old 11-07-2008, 04:28 PM
RodKnock's Avatar
Eric, do you have your cam specs? What are they?
  #123 (permalink)
Old 11-07-2008, 04:59 PM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
Rod,
Let me say first that Keith and I talked about the cam, and the system "will" take more cam, and make more power/trq.
Gross Valve Lift Intake .645
Gross Valve Lift Exhaust .635
Duration(@ .050) Intake 242
Duration(@ .050) Exhaust 248
Lobe Seperation 110.0
If you need more left me know and I'll send you a scan on the card.
E
  #124 (permalink)
Old 11-07-2008, 05:15 PM
RodKnock's Avatar
My cam is slightly bigger, though close enough, but has a 112 LSA. What's exactly involved with making the Dynatek system operational on your car?
  #125 (permalink)
Old 11-08-2008, 07:54 AM
Great Asp's Avatar
Well, if your motor is already in your car you have a leg up on me. After installation you will need to have it tuned. There is a "standard" tune for an FE on the box, but depending on the headers you have, and other variables, you will want to have the system tuned on a chassis dyno. My motor will again be tuned after installed in the car.
The DynaTek system comes with the software to tune it, but you need someone that can tune.
The only mechanical thing that I can think of was the fit from the intake to the heads and block. It needed work, but not much. Keith might be able to explain what they did, I do remember it was $180 to fit the intake to the heads and block.
E
  #126 (permalink)
Old 11-08-2008, 12:34 PM
Originally Posted by Great Asp View Post
666 ft lbs, and 634 hp !!!!
YEEEEEEEEEE-HAAAAAAAAA!!!
If it was me, I think I'd just stick with those numbers no matter how well it's tuned. "The Devil's Own Torque and More Horsepower Than You Can Use."
Congrats on a great build and thanks for sharing.
  #127 (permalink)
Old 11-10-2008, 10:15 AM
RodKnock's Avatar
E, yup, thankfully, my car is up and running. Where does the computer get mounted and I assume a sidepipe is drilled for the O2 sensor? I'm just trying to assess the difficulty factor in hooking up one of these setups. What was the "fitting" all about? Did they have to mill the intake and/or heads for a proper fit?
  #128 (permalink)
Old 11-10-2008, 04:28 PM
Great Asp's Avatar
Well, the box for the injection system will be under the glove box, and the 6AL will be in the engine compartment, "unless" they will both fit under the glove box.
I am going to get the small individual runner K&N filters, and have a chassis tune for both, no filters, and the K&N filters. I will not be using the "booties".
The side pipe is drilled and a bung fitted (welded) between the muffler and where the collector is, about as far back to the muffler as you can without getting into the muffler.
The fit between the intake and and the block and heads was not "true" to my understanding. I'll check with KC and see if I can get you a better explaination. But it could not have been much as it was only 180 bones. I'll check.
E
  #129 (permalink)
Old 12-05-2008, 12:20 PM
Great Asp's Avatar
Default Progress!
Progress!
The engine has moved into the same room as the roller, and will soon be installed!
Pics! The picture with the air filters is a trial, I have the shorter stacks and will try to see if I can run filters.
KCM does a nice job wrapping the car to keep dust and such off of it.
Michael, Thanks for the pics!
E
  #130 (permalink)
Old 12-05-2008, 02:33 PM
Cobra Make, Engine: SPF #1019
I see you have the Avons mounted as well... Sweet!
  #131 (permalink)
Old 12-05-2008, 03:41 PM
Great Asp's Avatar
Yeah, they look puny in the back.
The 305's were the best tire size (IMO), but even if you could get them they would be the BFG's......BOOOOOOO!!!!
I will have to see how the Avons are...
Thanks RR!
E
  #132 (permalink)
Old 12-05-2008, 03:50 PM
They are great. You will not reget them. Their stickiness in the corners reminds me of the GY Slicks I used to run on the track.
  #133 (permalink)
Old 12-05-2008, 05:45 PM
PatBuckley's Avatar
That looks like a lot of fun, Eric.
Congrats.
  #134 (permalink)
Old 12-05-2008, 08:10 PM
Great Asp's Avatar
Congrats.
Thanks Pat!
I am excited to get the engine in the car, but now it could wait until after January 2nd really.
E
  #135 (permalink)
Old 12-05-2008, 09:25 PM
rokndad's Avatar
Nice going Eric. Congrats on the Dynatek and the numbers. Be careful with that lethal weapon. You're almost there.
  #136 (permalink)
Old 12-06-2008, 10:20 AM
Scott M Jackson's Avatar
Club Cobra Member
Cobra Make, Engine: Ford F100; 496 Shelby, MassFlo, BlueThunder, Kee-Al-TopLoader, Detroit Locker
Thumbs up
ThIS IS exciting Eric. Many years ago I had one of the first Turbo Carreras and nobody could understand why I let my buds drive it. The reason was like this thread. Everyone enjoyed the experience. What's more is we shared it. Keep it up and congratulations.
Scott
Super Chief
  #137 (permalink)
Old 12-06-2008, 10:49 AM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Thanks Pat!
E
Hey Eric,
Your car is still in Arkansas? I would really like to crawl around and check out your setup. If, ahem.....I could hook up with you at a STL CC meet?
I have been thinking hard about changing out the DQ's for FI.
Very interesting thread, much fun to follow.
Congrats on following through and getting it finished.
  #138 (permalink)
Old 12-06-2008, 04:03 PM
Great Asp's Avatar
Originally Posted by lineslinger View Post
Hey Eric,
Line, the engine was built at KC's place in Arkansas, and now it is with the car at KCM in Plano Texas.
I will sure make the car available. I am already a member of Fords Unlimited here in da Lou-Town, and I regularly miss all the meetings
I am hoping to make some events in 2009, have to make a better effort.
Eric
Scott, thanks for the kind words. It has been a blast having the car built and thought other peeps might like to see how the DynaTek system comes together.
E
  #139 (permalink)
Old 12-07-2008, 08:25 AM
Cobra Make, Engine: CSX4000, 427
beautiful car.
curious though, I've heard that individual filters on a stack/weber set up will hurt top end hp by limiting airflow. Have you had your engine dyno'd with and without the filters installed, and if so, did they affect hp at all?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
  #140 (permalink)
Old 12-07-2008, 08:43 AM
Cobra Make, Engine: SPF#1245 w/ 1966 427 SO
Eric- Those Avon's DO look a skinny in the back. Are they 275's or 295's?
Oh well........they could be 245's and still have more grip than the 305 BFG's!
I like the look of those filters. Where did you get them? It will be interesting to see what (if any) changes in dyno figures will be with / and without filters.
This is becoming not only a very fun / interesting thread to follow, but also quite an informative one as well - especially to those looking into a FI system and/or thinking about purchasing Avons.
-Car is looking good buddy!
