10-02-2008, 12:46 PM
NJ
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Cooling Fan Relay Part #
Does anyone know where I can get a replacement cooling fan relay. The part # on the one that went bad was a Hella 4RA-940-010-67. I have not had any luck finding one locally. What are you guys using to replace them with, and where did you get them?
Peace through superior firepower...or is it horsepower? Either way, more is always better!
10-02-2008, 04:19 PM
Napa
Go to your local NAPA store and get an Echlin AR 274 relay. It is a standard relay rated for the current.
Almost any parts house can cross that number.......to any manufacturer.
10-03-2008, 09:51 AM
Fl
Cobra Make, Engine: SPF 2473, Roush 427R
If you want the exact Hella relay and not a generic one go online to Susquehanna Motorsports. www.rallylights.com
10-05-2008, 02:15 AM
it is just a 20AMP relay with a mount. you should be able to source a relay locally for 20$ or less.
or you can cheap out and go to the junk yard and pick up some monster AC relays for cheap and JB weld on a tab to bolt it down.
remember pinout ;
easy way to remember is 85-86 are the mag lock, 87 and 30 are the pathway
--Steve
10-05-2008, 03:18 AM
What's new???
Reason: too early in the morning
10-06-2008, 06:25 AM
NJ
I could not locate a direct replacement for the original Hella relay, so I opted for the Echlin AR 274 replacement from NAPA. It was $18, more than double what the Superformance dealers list for the Hella relay. Installed it Saturday, works with no problems. Thanks to all for the info.
Rick - the baby came three weeks ago. I talked the wife into letting me take the Cobra out to "test" the new relay Saturday night. It was the first time I had it out since the baby came. There is no better therapy to counter a screaming baby and dirty diapers than a spin in the Cobra
It took me two hours to make sure the relay was working properly
10-07-2008, 01:10 PM
Ont
hi there Archrms
was looking at your car in your gallery, and noticed that your car has the round tail lights.... did you special order that ? i dont think i recall seeing an spf with round tail lights.
10-08-2008, 09:37 AM
NJ
Maxum,
The round tail lights are a "special" order, as the rectangular lights are standard. It is a standard option that they don't seem to advertise, and was substituted at no charge.
