March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
  #21 (permalink)
Old 10-30-2008, 01:40 PM
Originally Posted by cobras View Post
could you give som more detail on the bracket you say to loosen to twist the turn signal arm to the left side. so i do not need to remove the steering wheel for this mod?
Here is a shot of my turn signal with the assembly that goes around the steering column. My steering wheel has a quick release hub on it, but just ignore that and envision that the steering wheel is still on it. You loosen the screws that hold the turn signal assembly and then rotate it around to the other side. You do not need to pull it off and then put it back on again. Now remember, your car is different than mine, but I'm betting that I'm right.
  #22 (permalink)
Old 10-30-2008, 02:28 PM
I think you may also have to loosen the turn signal cancelling cam screw.
  #23 (permalink)
Old 10-30-2008, 08:20 PM
does anyone know if this is true, i dont want to break anything in trying to do this
  #24 (permalink)
Old 10-31-2008, 06:41 AM
You can move the turn signal switch around as shown, but beware of a few things. First the wires to the switch are zip-tied tight against the steering column under the dash. You will need to cut a few of these ties loose in order to move the switch.
Second, you will have to spin the turn signal cancel cam also or it will not cancel correctly.
Therefore you might start this by removing the steering wheel and hub assembly. Looking at the cancel cam position and turn it 180* along with the switch.
I do have detailed instruction on this Email me and I'll see that you get them.
Mike E
Dynamic Motorsports
mike@dynamicmotorsports.net
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
  #25 (permalink)
Old 10-31-2008, 06:45 AM
FWIW, my turn-signals self-cancel about 20% of the time -- I'm generally surprised when they do. I kind of think of it as an extension of the Smiths gauges that require thumping in order to work properly.
  #26 (permalink)
Old 10-31-2008, 06:47 AM
On the temperature gauge issue I remeber reading on SCOF it is very important how you run the the "wire" between the sending unit and guage. I do not think it is a wire but I know it is wrapped in a spring type enclosue. You need to log onto scoff and read, it may not be your guage or sending unit. In fact I bet it is not.
  #27 (permalink)
Old 10-31-2008, 07:18 PM
Hi madmaxx thanks for posting, i have signed up to scof but have to wait till they aprove me i guess, i also joined the other sitr...dont remember the name off the top of my head now, but also have to wait till they aprove me, so not sure how long that will be. any chance any of you can post a link to that.
i will try logging in and seeing if it lets me in
thanks for help though
  #28 (permalink)
Old 11-03-2008, 05:53 AM
I think what madmaxx is trying to point out is, care must be taken when you run the capillary tube (wire). This is actually a tiny tube filled with ether. The expansion of the ether through the tube is what causes the gauge needle to move. Sharp bends, twisting or the accidental contact with an electrical source can cause the small copper tube to fracture and leak out the ether.
Mike E
Dynamic Motorsports
  #29 (permalink)
Old 11-03-2008, 06:26 AM
cobras
you have a pm
  #30 (permalink)
Old 11-03-2008, 03:40 PM
madmaxx i dont see no pm
  #31 (permalink)
Old 11-03-2008, 04:30 PM
I just emailed but you should also have on in your club cobra email.
  #32 (permalink)
Old 11-04-2008, 07:35 PM
got it mad max.
thanks so much for all your help, not just anyone would help me out like that.
take care
  #33 (permalink)
Old 11-04-2008, 07:44 PM
Mike E
Dynamic Motorsports
and thank you Mike, for taking the time to help me out and sending me that info, even tho the car was not sold through your dealership, you still helped me out, i can imagine how great the customer service is you offer to your customers.
thanks again Mike
