Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 04-26-2014, 09:25 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Default SBF Lower Water Pump Plug
This is for guys that don't have a heater, cup holders, or surround sound. Just kidding! I had to change my water pump last week and I had one of those HELP plugs on the bottom water pump heater hose fitting because I don't have a heater. It had cracks in it just after a few years. I had read of guys pulling the fitting and taping it for a pipe plug. This one was glued in there about 2+ inches, so I came up with this method.
I slightly cut the inside edge of the hose stop with a carbide bur so I could get my calipers inside the tube to measure the hole. I found it was .510. I then went to a machine shop and got a few of the widest oil passage plugs they had. The largest was .530. I sanded the inside of the tube and the outside of the plug. I spread some JB weld inside the tube and drove the plug in just past the hose stop seam, and then wiped some more JB weld in the seam to lock the plug in. I've run it twice; no leaks at all. Seems to work.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Old 04-26-2014, 09:50 AM
blown871's Avatar
Cobra Make, Engine: SPF
Should be pipe thread in water pump. Any hardware store.
Old 04-26-2014, 09:54 AM
Wbulk's Avatar
Nope, it's pressed in.
Wayne
Gil Younger
Old 04-26-2014, 11:19 AM
blown871's Avatar
ohhh............
10/4.
Old 04-30-2014, 07:28 PM
Cobra Make, Engine: CMC,Ford 302
Is there a way to pull the lower tube out without doing a bunch of damage? I bought a stainless allen head plug I was going to install, but wasn't sure how to remove the tube.
HTML code is On
