Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
January 2025
26 27 28 29 30 31
Old 06-03-2004, 12:04 AM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Default Sealing Windshield rubber to body
My windshield was prone to leak all along the bottom between the rubber gasket and the body. I used a 3M adhesive glass seal tape to "glue" the rubber to the body--this tape is used to seal glass panels in construction so the glass doesn't rattle against the frame, very strong, super thin tape, adheres to most any surface.
I cleaned the area under the gasket and the gasket with de-natured alcohol--I did pull the windshield first--applied the tape to the body, reinstalled the windshield, then "sealed" down the gasket to the body.
Only 2 small less than 1'' openings now at each windshield frame post where I didn't run the tape. Now I don't have water seeping in all along the windshield bottom like before.
FWIW
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 06-19-2004, 02:23 AM
Cobra Make, Engine: Unique 427SC, 403 FE. Dual Quad
Default Windshield Sealant
Finish the windshield frame post holes with clear silicone sealant. Loosen the frame trim plates and carefully run a bead where the frame passes through the car body. The sealant cleans up easily if you use a bit too much. It's been a while but I think I used Naptha to clean up excess silicone when I reseated the windshield to the body. -Aggressor
HTML code is On
