Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
  #21 (permalink)
Old 03-11-2005, 07:48 PM
Cobra Make, Engine: Venom, HO Ford 302 (40 0ver) Edelbrock polished aluminum intake manifold, Edelbrock carburetor, F-303 cam
LOOKS LIKE YOU DID HIJACK IT EARL!
  #22 (permalink)
Old 03-12-2005, 04:50 AM
Ron61's Avatar
Smile
Earl,
Sorry but based on one turn you still have the 2:73 gears. Easy way to count is that for each 100:1 gear ratio the drive line should turn 1 time. Example, with 3:50 gears one turn of the wheel should turn your drive line 3 complete revolutions plus 1/2 of another. I took the wheel off my car when I did it and used chalk to mark the rotor and a spot on top. I also started with the drive line so that one of the U-Joints was flat on top and marked it white so it was easy to count. I knew that I have 3:27 gears so when I did the test my drive line turned 3 and about 1/4 turns.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
HTML code is On
