1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
10-17-2004, 08:08 AM
Tx
Cobra Make, Engine: SPF Anniversary #1989. 427 Roush.
Tire Recommendations?
Have an SPF on order and going with a Roush 427 stroker. 15" wheels. Need some advice on tires. Purpose is a driver, street only. Had a Cobra a few years ago and there wasn't much available then in 15" that were round and had any speed rating. Anything out there that is available now? Need a round tire.
Bruce
713-922-4801
LIfe's journey is not to arrive at the grave in a well preserved body, but rather to skid in sideways, totally worn out, shouting..."Holy sh__,.......what a ride".
10-17-2004, 01:52 PM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
I've got Goodrich Radial T/As. Not very round (front end shake at 60-80) and they have siping which picks up small stones and throws them into the underside of the fenders. Goodyear and Yoko also make a 15 inch radial. Be careful of sticky treads (track tires) as they pick-up a lot of road junk.
Bob
10-17-2004, 04:49 PM
CA
Not much out there in 15 any more...
Bruce,
I concur with Bob on the T/As and the sticky treads on the street. After tiring from two sets of wheel shaking TAs on my last two cars, and rocks/flats on the big non-DOT Goodyears, I'm now trying the Yoko Avid STs. I was very reluctant at first. To my suprise they are decent to drive on in turns and at higher sustained speeds. For looks, the sidewall design is a bit noisy looking, but No more shake, very smooth, no rocks, and believe it or not, they stick fairly well. They are predictable performers and reasonably priced. I'm planning to burn up a set of these still waiting for someone to come up with a good 15" radial value in the right Cobra sizes for the street, in an American label... Til then, its Yoko Blah Blahs.
Duane
10-17-2004, 05:29 PM
Tx
Thanks Bob, I tried TA's on my last one with about the same results you describe.
Duane I'll try those Yoko's, thanks for the tip.
Bruce
713-922-4801
03-09-2005, 06:45 PM
AB
Cobra Make, Engine: #901 Superformance 427cid 540hp!
toyo
I'm looking around for a decent set to repalce the Goodyear GT2's. I found a Toyo Proxes S/T in 275/60/15 and a 295/50/15 but nothing in the 15" size for front tires? The tread looks cool, much different than anything else offered buy the others and "v" rated. I guess the Yokohama Avids are the best bet.
"This year Ferrari's Ass Is Mine"
03-30-2005, 01:50 PM
NH
Cobra Make, Engine: E-M , 5.0 efi
I like my Yoko Avids. They are much better than the T/A's
I have over 8,000 miles on them and still plenty of tread.
A much better tire all around. (couldn't resist the pun).
Harvey R
03-30-2005, 02:26 PM
Wi
Cobra Make, Engine: Arntz/SBC/Jag
A timely thread, as i have two sets of Trigo wheels on a Big Brown truck on their way to me as i type.
I was planning to do a set of the non-DOT GY's on one set for shows and track days, and some run of the mill's on the other set.
Been trying to decide between Dunlop Qualifier GT's (which i never had a very high opinion of) or a set of the Yoko Avid's which i keep hearing semi good things about.
I am also considering a set of BFGoodrich G-Force Drag Radials (at least in back) but i haven't heard much about how these are for cornering on. Roger Krause Racing hints that they are a decent autocross tire on their web site which is promissing.
Going to be ordering at least one set of rubber in the next week, so i appreciate all the input i can find.
03-31-2005, 08:54 AM
Renegade Nuns on Wheels
Oh
Yoko Avids. If you don't care about driving in the rain, Hoosier TD's. If you don't care about DOT rating, big letter Goodyears. If you care to wait, check out what TireGuy is coming out with.
Rick
03-31-2005, 09:38 AM
fl
Cobra Make, Engine: Lone Star 392 Stroker
I have read dozens of posts regarding this subject and have talked to many people who race and just have fun on the street. It seems the biggest complaint was getting the h.p. to the asphalt without going sideways or spinnig them in all 4 (5) gears. I modified my chassis to allow the use of 335's (Khumo ecsta's) in the rear and Khomo victor racers uo front. With a 4 link, currie 9" (373), tremec 6-speed and a 392 stroker (450 h.p.) the car hooks unbelievably, with very little side to side and once it gets hold its gone. Needless to say, very satisfied. A far cry from original but thats a call each builder has to make when it comes to performance. What are you willing to sacrifice in the way of originality to gain performance?
03-31-2005, 09:46 AM
MT
Check the post 'Cobra DOT Tires'. Use the Search CC button and enter 'Cobra DOT Tires.' You'll find the future promises an option we have not had to date...
A beautiful car, precisely assembled. Unfortunately I don't fit. Sold it after four hundred miles. Well, at least now I know a Cobra is not a car I can own.
HTML code is On
