Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
January 2025
26 27 28 29 30 31
Old 02-20-2009, 08:59 AM
redss454's Avatar
Cobra Make, Engine: streetbeast kit
Default E brake help
we have a ford 9 " rear with disc brakes the e brake cables have a round ball on the end going to the rear, the bracket on the brakes has a slot for the cable to hook on. does any one know what bracket I am missing to connect the round ball to a slot on the bracket?
thanks Jim
-Chris
Streetbeast Cobra Kit
71SS454 Chevelle with just a bit of work done to it
Old 02-20-2009, 04:29 PM
Monster's Avatar
Cobra Make, Engine: Arntz/Bennett, FE with lots of shinny parts that make it go fast
Jim,
Without any pictures I don't know if this will help but here's a link to an install of Ford 9" disc brakes. http://www.streetrodderweb.com/tech/...kes/index.html
Notice that they mention a replacement lokar cable this may help with what sounds like an issue your having with getting the cable connected to the "e-brake". Also, note that e-brake is an older term and you may want to try "parking brake" if your searching for install info on the web.
good luck,
Mike
HTML code is On
