Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 03-25-2012, 08:42 PM
Cobra Make, Engine: AC Adelaide Cobra - 351w & 4-Spd Toploader C/R - "Construction Underway!"
Default 15x10 American Racing with 5.5" BS on Jag rear?
Hi Guys,
I have been searching (with little luck) for anyone who is running or has run, 15x10 rims with 5.5 or greater BS on Jaguar Rear Hubs?
I have ordered my rims from American Racing and I need to run 0 offset for engineering requirements, however, I feel I may have stuffed up with my measurements. I neglected to take into consideration the hub fulcrum bearing boss and lower control arm (outer) mounting when measuring up for Backspace requirements etc.
Upon reflection and additional re-measuring I think the rim lip will be VERY close to rubbing on the hub!
Has anybody had any experience with this rim size/backspace combo on a Jag rear hub setup?
If so, where there any clearance issues and how did you deal with them?
Many thanks in advance.
Roy
Old 03-25-2012, 09:15 PM
BJ's Snake's Avatar
Should be ok. just done 15 x10 with 5inch backspace with no worries so another 1/2 inch should be fine.
289 FIA Cobras RULE!
Old 03-25-2012, 09:23 PM
Thanks BJ,
I did see your previous post regarding your new wheels. They look great:-)
5" BS was my preferred option however my engineer insisted on the 0 offset which equated to 5.5" :-(
Cheers Roy
