Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
December 2025
Like Tree2Likes
Old 10-04-2013, 01:37 PM
Cobra Make, Engine: B&B Ford FE from Southern Automotive
Default Compomotive HB17 Wheel Center
Recently damaged a Compomotive HB17 wheel and upon close inspection discovered that the center has a small crack. This a modular wheel so the good news is that the center can be replaced. The bad news is that I contacted Compomotive in England and was informed that they may have spare parts but are in the process of reorganization and nothing is available until the end of the year so I'm looking for another source.
The wheel is a Ford 5X4.5 bolt patern and the center is Compomotive part number HB701. If you happen to have a Compomotive 17 inch wheel the part number is easy to identify as it is cast into the back side of the wheel center.
A wheel center or if necessary entire wheel will work for me.
