Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
View Poll Results: Do you use Safety Wire?
Yes 173 91.05%
No 17 8.95%
Voters: 190. You may not vote on this poll
Like Tree26Likes
Old 04-23-2014, 09:43 AM
bliss's Avatar
Default Knock Off Wheel Safety Wire
If you have knock off wheels on your Cobra...
Old 04-23-2014, 10:33 AM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Why wouldn't you use safety wire?
Cobranut likes this.
Old 04-23-2014, 11:27 AM
I used to use safety wire. Now I don't bother. You can tell by the sound of the lead hammer hitting the spinner when the spinners are tight.
Old 04-23-2014, 01:35 PM
Our other vehicles have 4, 5 or 8 lug nuts per wheel. They are installed and snugged down as dry threads.
My Cobra has 1 hub nut and its lathered with anti-seize: (a). between the knock-off face where it mates against the wheel, and (b). all the threaded areas. The safety wire is 10 cents per wheel, of big time insurance and piece of mind for me.
Cobranut and 66AC like this.
Old 04-23-2014, 03:20 PM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
I've gotten in the habit of walking around the car and giving each safety wire a wiggle to detect if it has tighted up at all, an indication that the spinner was starting to come loose. The first time I put my wheels on one did come a bit loose after a few drives - the safety wire was tight as a guitar string. So now, I really whack the hell out of them with my lead hammer - hasn't happened again, but I still check the safety wire after each drive.
Mother and hauss like this.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
Old 04-23-2014, 03:36 PM
KarlCSX2498's Avatar
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
Hello, Yes, I always wire the knock offs. When I first was testing the go kart without the body, the LF came loose several times and it scared me. So I'm always sure the knock offs are tight and wired.
later, karl
Old 04-23-2014, 05:49 PM
1795's Avatar
I see no reason not to use safety wire, and besides it looks cool with the safety wire on. People see it and say, "Wow those are real knock-offs!"
Old 04-24-2014, 05:30 AM
Default Spider Web
I had the Cobra parked at a family get together. An adult guest I'd never met, walked up and asked if the red car was mine. I said yes, and then he mentioned I had a spider web on the wheel.
We walked over to the car. I asked what he was talking about. He pointed to the safety wire, and then a puzzled look spread across his face!
He apparently wasn't a car guy. And yes, this is a true story!
David
66AC and SGwick like this.
Old 04-24-2014, 08:22 AM
Default Going Wireless
....and you can tell by the sound of the brake rotor hitting the pavement when they are loose.
Just kidding with you JB. The choice is yours, but as 601HP says, it's cheap insurance, and as 1795 says, it pre-answers the question of "Are those real knock-offs?".
Grubby likes this.
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
Old 04-24-2014, 10:14 AM
Over the years I have had a variety of cars with knockoffs. None of them even had a provision for wire.....just saying.
Old 04-24-2014, 11:26 AM
Cobra Make, Engine: ERA 427 SO
Default Just for the heck of it...
You should add a bullet in the poll, "Yes, for safety" and maybe one, "Yes, for looks".
Ken
Old 04-24-2014, 01:30 PM
1985 CCX's Avatar
Did 289 Cobras with stock spinners use wire?
Old 10-09-2014, 12:35 PM
Larry N Johnson's Avatar
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Racing Cobras did not use safety wire during races.
No extra time and not needed for safety.
1985 CCX likes this.
Old 10-09-2014, 08:33 PM
Cobra Make, Engine: Superformance #522
Had one spinner loosen up, so always safety wire them. Use it as a check before each track or autocross run. Some event tech inspections require them. I find them fun to install ��
JLip likes this.
Old 10-21-2014, 09:49 AM
Cobra Make, Engine: SPF GT40
GT40's didn't either. Never had mine loosen even with many track days. Usually takes several whacks to loosen mine.
Old 12-16-2014, 04:02 PM
Cobra Make, Engine: ERA 289 FIA-351W (Stroked to 427 ci.)
I had one loosen that I thought was tight and the wheel partially galled the hub. I would never not use safety wire. When I am at speed I don't want to have to worry about the wheels!
KevinW likes this.
Old 12-16-2014, 06:10 PM
Obsessive's Avatar
Cobra Make, Engine: Shelby American, 1965 427 FE, alloy MR heads, Sidewinder intake
I have owned and driven several other cars with knock off spinners, all of them wire-wheeled and made in England. While none of them ever had any provision for safety wire, it should be recognized that none of them had anything close to the rear wheel torque of my 427. Add to that, high speed braking and absolutely no way of hearing the beginning of a loose spinner over side exhaust and the decision to apply safety wire feels like a no-brainer. It's easy to apply with decent safety wire pliers and looks every bit the part of a 60s race car. The only modification to the spinner needed is to drill a single hole and that can be done in minutes with the most basic cordless had drill. Why would you not run with safety wire?
Cobranut and Dominik like this.
Mike
Old 12-21-2014, 01:10 PM
Cobra Make, Engine: Backdraft, Roush 402R
Safety wire is a must for me. I got my cobra less than a year ago and taught myself how to do the wheels spinners. It's cheap insurance in my opinion.
Old 12-21-2014, 02:00 PM
Bernica's Avatar
Senior CC Premier Member
For anyone that has done over say 130mph in these cars, enough gremlins start getting into your head. Like tires, brakes, wheels, windshield etc. Wiring the wheels is just one less gremlin, at least for me!
Old 11-22-2015, 12:59 AM
Cobra Make, Engine: Shamrock
Neutral
I have this image in my mind of spinner loosening off on the front wheels and the wheel moving away from the drive pins and suddenly you are at speed with no brakes or brakes on only one side. Not a good time to discover the problem when you are braking heavily.
Also the car steering from loose rear wheels.
