1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
2Likes
Post By Karl Bebout
Post By Jim Kellogg
09-01-2014, 04:52 AM
DXB
Mickey Thompson
Used the search and nothing came up, wondering if anyone here tried the Mickey Thompson Sportsman S/R on their Cobras and what to expect from them.
09-01-2014, 05:06 AM
AZ
DWRAT, over on AZ Cobras just put a set on his SPF within the last couple months. Might want to send him a PM. Think he likes them. Also heard that Cooper Cobras are the same tire for about 20% less $$$.
Karlos
09-01-2014, 05:30 AM
NY
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
I recently put a set of M/T Sportsman S/R tires on my SPF and so far am happy with the ride and looks. I am running 26x12.00R15 in the back and 26x10.00R15 in the front. The 28's seem to be a little too tall for our use, but I have seen some guys running them. These tires are made by AVID and in my opinion are a great deal for the price if you are looking for a high performance street tire with some track capabilities.
I started out with BF Goodrich tires that came with the car (too hard and break loose too easily) then wore out a couple of sets of Yokohama Avid S/T tires and liked them a lot. They were reasonably priced, had predictable dry handling and went well in rain and snow. Unfortunately, they were discontinued by the manufacturer. I ran 295/50R15 rear tires and 245/60R15 tires in the front, just so you know what I am comparing the S/R tires to.
The Cooper Cobra tires are NOT similar to the MT S/R tires. They ARE similar to the MT S/T tires, of which I have also heard good things about. The MT S/T tires are less expensive than the S/R tires, and they are a completely different tire.
Hope this helps!
Jim
09-01-2014, 05:56 AM
PA
Cobra Make, Engine: Superformance #522
Great street tire.
09-01-2014, 06:21 AM
Q
This is from my iPhone, so I hope it works for you. I find Google search results are easier to sort through, even when it's specific to ClubCobra search results.
https://www.google.com.au/search?q=m....clubcobra.com
Mickey Thompson Tires
Craig
09-01-2014, 07:18 AM
ME
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
I'v gone from the MT S/R's to to Hoosier billboards to now MT S/T's . For all around street use the MT S/T suit me very well & have a comfortable ride and predictable break points which allows me to get used to the max break aways points in the curves. I am very pleased with them. The price is reasonable also. It should be noted the the Cooper Cobra's are the same basic tire as the S/T's & both are made by Cooper Tire; as are Avon's. But the S/T's & Cobras are priced much less than the Avon's. They also don't have the speed rating of the Avon's, but for street crusing & the occasional hard romp they work well for me.
09-01-2014, 10:15 AM
AZ
Hey Jim, thanks for setting me straight on the MTs. STs/SRs got me so confoozed.
Karlos
09-01-2014, 02:58 PM
NY
Most SPF owners I know of that are running Mickey Thompson tires are running the S/T. Many others are running the Cooper Cobra tire. Both groups seem to be very satisfied with their choice.
I am very happy with my S/R choice, but as I said, I haven't put too many miles on them yet. My SPF was in the shop for awhile getting some repairs and upgrades, and she only came back home recently.
I am still sorting out some chassis and handling issues due to my high mileage (80k plus), effects of winter salt (several years but - no more!), and the car sitting for so long. Also getting used to my new (wilder) motor and trans setup. My next upgrade (hopefully a winter project this year) will probably be the R/T ball joints.
Cobra Valley's R/T Super High Performance Ball Joints
I am chasing a vibration in my SPF, and feel that the ball joint change should do the trick. Next spring I hope to start racking up the miles again, and should have a better feel for the Mickey Thompson S/R tires!
09-01-2014, 03:21 PM
NY
Here are a couple of photos of the Mickey Thompson S/R tires on my SPF so you can see what they look like.
Fronts are 26x10.00R15
Rears are 26x12.00R15
I had to search awhile to find photos of the 26" MT S/R on a Cobra, so perhaps this will help. Some like the 28" tire, but it is too tall for my taste.
Jim Kellogg
09-01-2014, 05:12 PM
NC
Cobra Make, Engine: Superformance No. 1359 / 351
I have put about 4k miles on my SPF MT S/R tires. I will replace with S/Rs if still available when the time comes.
09-22-2014, 07:54 PM
CA
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Have the M/T S/R's on the rear of my 289FIA.
Like them very much. About 3000 miles on them
They are MUCH stickier than the Dunlop G/T Qualifiers.
This is a post I made several years ago.
Mickey Thompson S/R radials
Have just added two photo's of the S/R's in "my photo's" section
Pete
ERA 289 #2027
09-23-2014, 06:39 AM
AZ
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
I have Mickey Thompson S/R tires on my Hurricane, 7 years old and look like new, very little tread wear and no cracking. I have put then through the paces but don't abuse them, no burnouts, have 21000 miles on them.
Going to replace them due to age only.
Good luck, Bill
Failure is not the outcome, it's not trying.
09-23-2014, 10:45 AM
CA
I only wish they had a vintage looking tread pattern. Performance and size sound perfect. Are the ST's that much of a step down in performance?
John
10-09-2014, 11:24 AM
UT
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Mickey Thompson Sportsman S/T Tires
S/T's here, very very pleased.
- Roll smooth, no vibration at any speed
- Quiet, no tire noise
- Decent traction, way stickier than the GY GTII prior
- Period correct look
Two Kirkham owners here in Utah run them, too. Good comments even on the track!
