-   Tires and Wheels (http://www.clubcobra.com/forums/tires-wheels/)
-   -   Wheel straightening (http://www.clubcobra.com/forums/tires-wheels/141693-wheel-straightening.html)
t walgamuth 11-15-2018 01:23 PM
Wheel straightening
Hi all. I have a 16" compomotive wheel which was cracked by a previous owner. I have had it welded by a very good welder and now find the wheel is also bent. Any body know of a shop which will straighten it for me?
I'd buy a new or used wheel if I could find one with all the right dimensions and the 5 on 5" lug pattern of my car.
twobjshelbys 11-15-2018 01:27 PM
I wouldn't drive on a wheel like that. The process will weaken the metal.
t walgamuth 11-15-2018 01:38 PM
Thanks Tony!
The fellow who welded it, Michael LeVeque said he has a lot of experience with welding wheels that will be track driven with excellent success. He sold his lath though to finance construction of a new shop so cannot do it himself.
Other thoughts?
joyridin' 11-15-2018 02:50 PM
There is a local place called Blackburn wheels that does it. The place is huge. Here is their website. If you call, talk to Brent.
https://www.blackburnwheels.com/
MOTORHEAD 11-15-2018 03:11 PM
You're in Hoosierland, as in "Hoosier Tire" located in some little town just south of So. Bend Being in the racing business, they probably run into bent wheels frequently, and may be able to help you. Worth a call
I'll be in So. Bend next week. would like to take a peek at that machine of yours, if feasible. Will be visiting my son & family, ( he's a Purdue eng grad, knows the way to Lafayette)
Ted Radtke
e-mail "srqradtkes@msn.com"
Jim Vander Wal 11-15-2018 03:29 PM
I've used these guys with great success. They've been fixing wheels for many years.
Not cheap but excellent work.
Wheel Collision Center Bath PA- Excellence in Refinished/Used Factory OEM Aluminum Alloy Wheel Rim Sales & Alloy Wheel Rim Straightening Repair Refinishing & Recycling! - www.oemfactoryrimwheel.com Excellence in Refinished/Used Factory OEM Aluminum A
Jim
t walgamuth 11-15-2018 05:24 PM
Thanks Brent! I'll check that out!
t walgamuth 11-15-2018 05:27 PM
Ted Radtke
pm sent.
t walgamuth 11-15-2018 05:28 PM
Originally Posted by Jim Vander Wal (Post 1453949)
Thanks Jim! I'll give them a shout.
t walgamuth 11-15-2018 05:56 PM
Thanks for all the comments!
t walgamuth 01-16-2020 09:15 AM
My hub is 5 on 5" bolt pattern but if I can find a 16" center section I am willing to change the bolt pattern on my hub.
Anybody have a 16" center or a damaged wheel with a straight 16" center?
spdbrake 01-16-2020 10:53 AM
This set may still be available.
PhotoPost Classifieds - 4 Compromotive Wheels, Spinners and Tires - Powered by PhotoPost Classifieds
t walgamuth 01-16-2020 10:58 AM
Thanks SpD!
OK so those are knock offs. Nice! Can I get them drilled for bolt on?
spdbrake 01-16-2020 06:54 PM
Those are bolt on. They just have lugnut covers like these
ET Wheels by Team III Wheels
Btw if you ever need barrels (inner or outer) for offset changes , etc...
https://www.felgenfuchs.de/en/home/
t walgamuth 01-16-2020 07:37 PM
Oh, cool!
Thanks Spd!
t walgamuth 01-17-2020 05:50 AM
looking at IMage wheels in the UK.
