1Likes
Post By mrmustang
03-22-2023, 11:32 AM
IL
Cobra Make, Engine: Factory Five, MkII, 302
Wheels & Tires - MKII
What's the largest wheel & tire combo for this car? The rear axle I'm told is from a 2004 Mustang, if that matters. I'm wanting to fill up the wheel wells as much as possible, without rubbing issues of course. I'd prefer 17" if possible, as I like the look of low profile tires generally.
And who are the best wheel suppliers?
TIA!
03-22-2023, 12:15 PM
SC
TIA!
What is your FFR chassis number (last four of VIN), also, does your car have rear coilover shocks, stock Ford rear coils and shocks, or perhaps an early 3 link rear? Each has it's own particular set up limitations, which is why I'm asking.
Bill S.
03-22-2023, 05:36 PM
IL
Bill S.
The entire VIN is FFR3315K. New to Fords, but I'm assuming this is the stock setup.
03-22-2023, 05:50 PM
IL
After looking through a few pics online of other MKIIs, it looks like coilovers are a bolt-on? I should have added in the original post that I'm not opposed to making changes to fit 315/17s in the rear. I am a fairly decent welder if that's what it requires.
03-22-2023, 06:13 PM
SC
Given you have the stock donor 4 link, you are going to be limited to 245/45/17 on a 17x8 rim in the front, and a 17x9 rim in the rear (stock late model, 1987-1993 mustang offset)
You are going to need to cut off the rear coil spring (towers) mounts flush with the upper frame, you will then need a SN95 rear (slightly wider than a 79-93 fox rear end), at that point, you are best to spend a little extra money and get the FFR 3 link retrofit kit. You can then add the 17x10.5 rims (94-2004 offsets) in the rear in order to fit the 315/35/17 tires, yet you still might have some clearance issues, again, depending on which rear axle/housing setup you have.
Bill S.
03-23-2023, 08:37 AM
IL
Bill S.
If I'm going to swap out the rear anyway, are there any affordable IRS options? Or is that an entirely different price range, with shocks, brakes, etc.
Reason: Added detail
03-23-2023, 09:16 AM
SC
There is nothing "bolt in" for an IRS option, the only bolt in option is the 3 link retrofit, which will give you the most intuitive handling without spending $6,500-$7,500 having someone like Mike Everson (Massachusetts) retrofit the IRS to your earlier chassis.
Bill S.
03-23-2023, 09:40 AM
IL
Bill S.
Cool, thanks. Are there any particular SN95 rears that are preferred? In terms of gear ratios, limited slip, etc?
03-23-2023, 10:47 AM
SC
All personal preference, depending on your particular wants and needs.
Bill S.
03-23-2023, 10:54 AM
IL
Bill S.
I found a few rear ends locally at salvage yards from 2000-2002 GTs. 3.27 gear ratio. Think I'll go that direction.
