SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
December 2024
  #21 (permalink)
Old 04-05-2010, 08:37 AM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
Originally Posted by kayakjack View Post
Ray,
I wonder if the sounds coming when you were in 5th gear could have been due to low fluid level in the transmission? You drained and filled. The old stuff looked fine. You filled with good stuff. I assume there was good stuff in it before. If it was low and is now full, maybe that (low fluid level)would cause the symptom and provide the cure (proper fluid level).
Jack
Could be, Jack. Unfortunately, the old oil went straight to a drain pan with a lot of other gunk. Couldn't really measure. Old tranny oil looked almost exactly like the new stuff I was putting in (liquid gold).
Not sure if groaning is a known symptom of low tranny fluid in a Tremec. Maybe the tranny gurus can verify? I was pretty convinced it was the rear end judging from the directional "feel"; especially since I've had the top up until last Friday...
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
  #22 (permalink)
Old 04-05-2010, 09:27 AM
Got the Bug's Avatar
Originally Posted by JCoop View Post
MM, I would have gone with the 75W140 too, which, I think I will do after I install a drain plug as recommended at SCOF. The oil that's in there now will be an expensive flush, as I really couldn't suck all the old oil with a hand pump.
But, that would be a midsummer doldrums kind of project...
Ray,
I took a look at the instructions on SCOF for drilling/tapping the rear end for a drain plug. It looks like a nice upgrade and would make the job a lot easier.
Have you ever run across any info regarding a basic recommendation regarding the miles between rear end fluid changes for a car that is only driven on the street? I'm guessing that it's similar to the maintenance requirements for the trans fluid.
Doug
  #23 (permalink)
Old 04-05-2010, 09:52 AM
the scof refererences the old ford rear end, not the new dana rear end. I still have never seen a formal fluid recommendation.
  #24 (permalink)
Old 04-05-2010, 10:04 AM
JCoop's Avatar
Originally Posted by Got the Bug View Post
Ray,
Doug, judging from this experience and what I saw, I'd say a change is called for after the first 500 miles, then another after 5000. $50 is cheap insurance.
I don't know if mine was ever changed after the initial break in as I'm the second owner. I'll put another couple of hundred miles and change it again just so I can see what's happening after this.
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
  #25 (permalink)
Old 04-05-2010, 10:26 AM
I think they're in the process of building a maintenance page/buyer's checklist page, but nothing is up on the site yet.
Doug
  #26 (permalink)
Old 04-05-2010, 11:36 AM
DAVID GAGNARD's Avatar
I changed the fluid (Redline MTL) in my Tremec after about a total of 20,000 miles, of which were at least 100, 1/4 mile drag passes and at least 1,500 miles on 4 different road courses, still looked like new!!!!!!!!!!! car is a 3100 pound 65 Fastback.......
Put in the GM recommend stuff cause I got it at cost at the local dealer, can't tell any difference in the 2 fluids........
In my race car, I change the fluid in the trans. (toploader) and the 9" rear once a race season.......five or six years now and no problems with either of them.........
David
DAVID GAGNARD
