SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2025
26 27 28 29 30 31
Like Tree3Likes
  #21 (permalink)
Old 01-24-2015, 10:15 AM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Jon,
Yes, I bought my TKO 600 from Bob Hanlon and have been to his shop a few times. I bought it with the carbon fiber blocking ring and Pro 5.0 Shifter upgrade. Since this is my first Cobra I have nothing to compare it to, but I'm very happy with the way it shifts and feels. I don't have a high-revving engine so maybe didn't need the blocking ring upgrade, but it wasn't that expensive so I went for it.
By the way, Bob is a great guy and knows his stuff. No brainer for me since he's local.
Kevin
saltshaker likes this.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
  #22 (permalink)
Old 01-24-2015, 01:23 PM
eschaider's Avatar
Originally Posted by Detroit Bill View Post
Is it worth upgrading a Tremec 600? I see Liberty, which is local to me has upgrade packages.
If you buy the trans from them for an additional $300 installed they will
- Bronze Shift Fork Pads
- Surface Enhancement Processed Hubs & Sliders
- Internal Shift Linkage Upgrade
- Liberty's Exclusive Threaded Front Cluster Bearing Support
- Carbon Fiber Blocking Rings—2nd, 3rd & 4th Gear
Brent Lykins also has a Sure Shift upgrade for around the same price. I am not sure what is in that package.
Lykins Motorsports, LLC
Since I am buying a new trans for my car I could get it upgrades already installed and avoid having to pull the trans if I wanted it done?
Searching the internet indicates
- This trans varies a bit and experiences differ.
- Needs to be broken in
- Is difficult to shift from 2-3 fast
- I also read here that unless you are shifting over 6000 RPM upgrades do not help
There is also conflicting information on shifter upgrades.
Any experiences?
I know Brent Lykins works on these, I am hoping he will chime in.
Bill, I bought the entire Liberty "upgrade" package a couple of years ago. I live in CA and wasn't keen about the shipping cost out and back. I bought the parts and did the work myself. It takes about four hours if you have never had one of these things apart before. The Tremec manual makes the job much easier.
The threaded bearing support requires a mill and more than average skills. If you go for the bearing support (a good upgrade) you will probably want Liberty to do the deed unless you have access to the machinery necessary.
The 2 to 3 shift problem is a transmission gear interlock problem as explained to me by Liberty. Their internal linkage upgrade addresses the timing problem quite nicely. While I have never seen Brent's solution I suspect it is similar and works equally well.
If you are within driving distance of Liberty, drop the trans off and pick it up later letting them do the work for you. This upgrade is a no brainer (after you have experienced it) and you will forever be glad you did it. BTW I strongly suspect everything I have said about Liberty mod package is equally true of Brent's TKO600 mod package.
Ed
  #23 (permalink)
Old 01-25-2015, 08:35 PM
Cobra Make, Engine: CSX4000, 427
I'd just get a toploader.
Close ratio - get 3.50's to 3.70 rear gears
wide ratio - get 3.0 to 3.30 rear gears
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
