09-30-2019, 05:44 AM
AR
Cobra Make, Engine: BDR, 418
External slave
I recently had to replace the master clutch cylinder...not a problem after I figured out the only way to access it was removing the side vent...it was leaking bad and the goop that came out looked like cable lube graphite....the external slave wasn't leaking and although I ordered a new one, I chose not to replace it until it gave out or started leaking...very simple to replace it...flushed out the system and used Dot 4...clutch is a little heavier but much more responsive...the Tremec 5-speed shifts awesome now....
