SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
December 2024
  #21 (permalink)
Old 04-10-2005, 04:17 PM
Ant Ant is offline
Default Jerico five speed
USD$6200 includes shifter, yoke and bits like spigot bearing, driveshaft UJ's.
A J. Newton
The 1960's rocked!
  #22 (permalink)
Old 04-10-2005, 05:01 PM
Cobra Make, Engine: Almac Cobra 427R
Ouch - they arnt cheap are they!
  #23 (permalink)
Old 04-12-2005, 05:01 PM
Cobra Make, Engine: CSX4000, 427
Ant,
how did you decide which ratio's to get, what did you base it off of?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
  #24 (permalink)
Old 04-12-2005, 05:24 PM
Ant Ant is offline
Default Gear ratios
Anthony,
I am still working them out, but first I used the Richmond gear optimum calculator to get and idea of different combos. Then used either Smokemup and this one http://www.geocities.com/z_design_st...ion_z28_6.html
With my experience on local race tracks I thought whats the point in having an 85mph second gear and evenly spaced around that when some second gear turns are around 55-60mph and the engine will be off the camshaft, so I am going for a lower set with speeds of:
7000 on 3.27 with 25.6" tires
56
80
106
134
164
Some race guys have second/third/fourth all about 15-17mph apart to accommodate these turns. We used to have an air force base with really high speed corners so it didnt matter so much. Another point I am going to run more of a revver whereas if I went to a 406 race engine ratios would be less of a problem due to lower down grunt.
A J. Newton
The 1960's rocked!
  #25 (permalink)
Old 04-19-2005, 04:37 PM
164 Ant? Where are your priorities? Hehe
Wont you miss the near 200mph?
  #26 (permalink)
Old 04-19-2005, 10:02 PM
Ant Ant is offline
Default Jerico 5 speed
Bevan,
I think those days are gone a bit, as the roads here arent that brilliant, and with the car will still do about 170mph at 7000.
I still havent ruled out an alloy BBC, we havent been able to get good build sheets on alloy SBF yet but have been in contact with Joe Fontana, he makes a mean cleveland block with good oil system, and there are plenty of high flowing alloy heads that are equivalent to the cleveland available. Decisions decisions.
A J. Newton
The 1960's rocked!
  #27 (permalink)
Old 04-21-2005, 05:01 PM
I must admit - the airport circuits are all gone now - nowhere left to go that fast unfortunately.
I probably would go with a small block if I was starting from scratch - less torque, less power - can use it more!
  #28 (permalink)
Old 04-21-2005, 07:37 PM
Clois Harlan's Avatar
Ok Scott I want to see the video! The one you post a couple years ago was tremendous. Reminds me of what I need to do to get closer to your times (since I can't hit that 8000 RPM mark like you do with your stroker I am going to need to finesse my gearing a little better).
Clois
"Let's roll"
"Be part of Something Good
  #29 (permalink)
Old 05-02-2005, 09:24 PM
Default Jerico`s
I have no personal experiances with the Nascar or road race Jerico 4 speeds, but I have been running a Jerico DR-4 in my 2 drag cars for some time now. It has been in my low 10 second 428FE powered Ford Fairmont for 6 race seasons, & this year I converted it to my 85 Mustangs 302. After hundreds of 6000-6600 rpm clutch drops, I have yet to hurt it whatsover. In fact, when we pulled it apart to change the gear ratio`s for the 302,this was the first time the covers were removed since I first installed it. Awesome race trans, but I certainly would not want to drive it on the street! In addition to the very noisy straight cut gears, there is considerable backlash when getting on & off the throttle. Although it shifts like the proverbial "hot knive thru butter" under full throttle, it does not like to be "granny shifted" (very crunchy noises!), nor does it take kindly to downshifting. Again, these are based on my own experiances with the drag racing unit, a road race slider equipped unit may be a totally different animal.
78 Fairmont 428CJ 4speed ET10.03@132.17mph
1985 Mustang 302 5speed 12.31@106.9mph
  #30 (permalink)
Old 05-03-2005, 01:48 AM
Ant Ant is offline
Default Jerico 4 speed.
Rory428,
I think the road race sliders would be much easier to drive on the road than the DR4/DR5, I realise they are a race trans, but with a little bit of practise not a problem at all.
G-force make a real tough T56 with syncos and semi straight cut gears, but they are approaching $7kUS and 130Ibs......heavy!
With careful selection of running gear components weight savings of 50Ibs trans and another 85Ibs with an alloy engine = 130+Ibs.
A J. Newton
The 1960's rocked!
