SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 12-16-2003, 05:31 PM
REDSC400's Avatar
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Ok, I did the Driven Gear change. It was not too hard at all. Actually, the hardest part was figguring out how to get the bolt out as there is not too much space in the tunnel to work on this. I used a 7/16 socket on a universal joint on an extension. That did it nicely. Once the bolt that holds the retainer was out and the retainer moved away, then I pulled gently and tugged on the cable to no avail.
So after a cup o coffee I just got in there with gloves on and gave it one nice firm pull and it popped out. Surface tension was hoding it in. The gear pulled off and the new one was in jiffy quick.
Thanks for all the advice and guidance Guys.
Cheers.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
  #22 (permalink)
Old 12-16-2003, 05:43 PM
I have a 3:31 rear gear in my car and ERA reccomended the white gear.
  #23 (permalink)
Old 12-16-2003, 07:25 PM
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
I'd hate to be in a position of disagreeing with ERA, but according to the article about this on the Boss 302 site (http://www.boss302.com/speedo.htm), if your wheel diameter is 26", you need the green tip (18 tooth) driven gear. Southern told me the same thing (use the white/pink) and I don't think it's correct either. steve
steve meltzer
"I may be wrong, but I'm never in doubt"
  #24 (permalink)
Old 06-16-2004, 08:39 AM
Art, Steve,
We had the 18 tooth speedometer driven gear made so you do not have to struggle to find it in the future.
www.davidkeetoploaders.com
  #25 (permalink)
Old 06-16-2004, 08:43 AM
Club Cobra Member
David, thanx for the update....I hope I never need that little jewel, but at least I now know where to get it! steve
steve meltzer
