April 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
01-21-2004, 01:09 PM
David - As soon as you have photos of the complete aluminium toploader could you post them on Clubcobra. The added bonus for people this side of the pond is that shipping will be cheaper than for the cast iron lumps.
Andy
Promoting 289's in a country awash with 427's
Advertising
01-23-2004, 03:32 PM
VA
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Hello David,
I'm sure this isn't the first time someone has mentioned this to you.
I'd guess there would be a bunch of Cobra owners with Tremec transmissions that would beat a path to your order desk if you offered a close ratio gearset for these boxes. About a 2.75 - 2.85 first, and a .75 - .82 fifth. Just imagine, people could use all five gears!
01-23-2004, 04:08 PM
CA
Aluminum toploader? If the price was the same, yeah! For me the weight would be the only consideration but a polished unit sure would look nice on a show car! I'd rather stick with the cast housing for originality. Ask me again tomorow
Hyde D. Baker
01-23-2004, 05:36 PM
Alloy Toploader
An added bonus to my way of thinking, is that an aluminium cased Toploader is very period and would be totally acceptable for vintage racing, some people are now using Jericos. The PDL Mustang is a very famous (in this neck of the woods) old 1977 circa racing sports sedan, they have taken out the Toploader and fitted a Jerico. I dont think the lap times have changed though but its easier to change gear!
A J. Newton
The 1960's rocked!
03-08-2004, 06:12 PM
Here is a picture of the first finished tailhousing in aluminum. Weight is 8 pounds.
We are also finished with our aluminum linkage with heim joints.
03-08-2004, 06:57 PM
Banned
david
the tail housing looks great. will you also be producing the long tail shaft and or the narrow bolt pattern cases in aluminum? thanks.....john
03-08-2004, 07:12 PM
I have not decided if we are going to pursue any of the 27" tailhousings. The case we are making in iron and aluminum have the inner bolt pattern to be used in a narrow bolt pattern application.
03-08-2004, 07:13 PM
Fl
Cobra Make, Engine: Hunter with a 4.6 supercharged
How much is the aluminum tailshaft housing??
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
03-09-2004, 07:34 PM
The aluminum tailhousing should be around $280. They will be 28 or 31 spline.
05-04-2004, 08:10 AM
Here is our first new aluminum maincase. Weight is 12#, the cast iron ones are 27#
05-04-2004, 09:18 AM
Cobra Make, Engine: KMP
David:
When do you think that complete aluminum transmissions and tail housings be available?
Lew
I'm no expert.
05-04-2004, 05:24 PM
GA
I am also interested -
David - what is the torque rating on the aluminium boxes and about what is the weight difference?
Has someone asked how much they are going to be yet? If not, how much are they going to be?
Pat
05-06-2004, 11:39 AM
The aluminum case should not affect the strength of the unit that much. I would not use one for heavy duty drag racing but for street and vintage road racing it should be fine. It looks like 60 days minimum before they will be ready. Price should be around $2000 for a completely new large spline aluminum unit.
06-16-2004, 12:49 PM
We have assembled the first large spline aluminum unit and the total weight is 74#. A small spline unit should be slightly less.
06-16-2004, 05:47 PM
Cobra Make, Engine: Once Owned CSX4803, CSX803 block, Keith Craft 468, Suspension by Tom Barnard, Built by Kris Kincaid
Re:
How much does a standard Toploader weigh? Thanks.
Bluedog
06-16-2004, 05:52 PM
KY
They weigh about 100-115 lbs don't they?
06-16-2004, 05:55 PM
Super Moderator
CA
David
Any chance of taking a slightly used and always babied regular Kee toploader in exchange?
Jamo
06-17-2004, 11:58 AM
Jamo,
Keep in mind I was at the Fling last year watching the burnout action. We could switch all of your seasoned parts into an aluminum case and tailhousing.
06-17-2004, 12:01 PM
Super Moderator
CA
I think I had the shortest Kee warranty ever! You said it ended that night!
Jamo
06-17-2004, 12:09 PM
David:
How about an UNUSED David Kee Toploader in trade? Mine has been sitting at Southern Auto since you shipped it many months ago.
How much does a regular TL weigh?
Thanks,
Lew
Lew
I'm no expert.
