SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2025
26 27 28 29 30 31
Old 03-08-2005, 03:12 PM
Default Unconventional, but clutch is fixed!!!
I posted a problem last month about my clutch slave cylinder not having enough travel to work properly. I ended up going from a 3/4" master cylinder to a 7/8" master cylinder. And that DID NOT fix the problem. The slave cylnder would now move full-stroke, which it did not do before. But it still did not have enough travel to fully disengage the clutch.
I ended up calling the manufacturer, CNC Brakes, again. They advised me to unscrew the dry end of the cylinder and remove the return spring and put a return spring on the clutch fork instead. That ended up giving me the required travel! Actually, I think I gained about a full half inch of slave cylinder travel. The clutch now works beautifully.
So after all the screwing around, it turned out to be a five-minute fix.
I'm only posting this on the outside chance that it may help someone in the future.
Old 03-09-2005, 06:16 AM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
For them to provide a quick fix, they must have been down this road with others. Glad to see your problem was resolved without a lot of unnecessary work.
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
