08-30-2006, 08:11 AM
W.A
Cobra Make, Engine: Lucus shell, Arrow chassis, efi 5L HO, 5 spd supra, Diff 3.73:1, Rear tyres 275x60-15
I modified an existing hydraulic clutch pedal box out of a mitsubishi starion, and just grafted the setup to suit my needs. I made brackets to mount the master & slave cylinders. I would never concider to use a cable setup ever again... hydraulic is the only way to go!
I'm not sure if there is a conversion kit or not, but I do know you can buy master & slave cylinders new and they are not that expensive.
Simmo
Black Rubber Needs To Be Layed
