09-04-2006, 04:58 PM
OH
Cobra Make, Engine: CSX4000, 427
Originally Posted by BBRONKO
Can you give me a way to find out if it is a big or small input splines shaft .
The small input shaft is 1 1/8" in diameter, while the big input shaft is 1 3/8".
Some of the early 427 cobra's came with big input and small output trannys, so if the rear spline count is 28, it could be either. Big output spline count is 31.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
