March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 01-28-2007, 10:08 PM
Mike Bartlett's Avatar
Cobra Make, Engine: CSX4771-CF. 1966 427 S/O
Default Conversion from .64 to .82 for T600
So, I was one of the bone heads who ordered the .64 with 3:31 gears. 1800 rpm' at 70 mph doesn't cut it with my motor. Pings at the slightest hill when in 5th.
Has anyone converted there's from .64 to .82? How do you like it? Do it yourself or have a shop do it? How much did it cost?
Thanks.....
Rubber peelin' gears a jammin'!
Old 01-28-2007, 10:25 PM
wtm442's Avatar
Beam Me Up Scottie
I do not know about changing 5th gear, but if you are pinging under slight load, back off the advance or use higher octane gas.
Warren
Old 01-28-2007, 10:51 PM
Rick Parker's Avatar
Shift to 4th???
Old 01-28-2007, 11:05 PM
wtm442's Avatar
Beam Me Up Scottie
That low 5th gear is useless with 3:31 rear gears. I have same tranny but 3:73 rear gears. Check out price of new rear gears ... car will go faster in lower gears, or spin the tires easier
Either way will be expensive when compared to Rick's comment.
Warren
Old 01-29-2007, 06:06 AM
Jimi G's Avatar
Thanks.....
Mike,
The swap can be alittle difficult if you have never been inside of a standard transmission before, as for the parts you can expect to pay somewhere around $500.00. Changing the rear gears to 3.73 will be the cheapest and easiest way to help raise your rpms in 5th. If you can give me some specifics on your car I can see what your rpms will change to with the rear gear change or the 5th gear change in the transmission. I will need to know your rear tire size and I can tell you the difference you will see. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 01-29-2007, 06:18 AM
SPF1061's Avatar
Cobra Make, Engine: Superformance Mk III / Windsor platform
Mike -
What engine are you running? As pointed out , back off the timing if you're pinging under a little load at 1800 rpm. That's bad news.
As to gearing. Dropping the rear to 3:73 may be the cheapest change - but not the best solution. 1st gear will become absolutely useless for anything other than setting the rear tires on fire. I changed my 427R SPF from a .64 od / 3:73 to a .82 od / 3:23. This was one of the best mods I have done to the car. 100% improvement in drivability. First gear and fifth gear both turn into usable performance gears. If you have a larger engine with some low end torque, I promise you, you will love this combination. If you have a high revving peaky smaller displacement engine this gearing may not work as well. Good luck with your decision and ahve fun!
-Steve
Old 01-29-2007, 08:57 AM
CobraEd's Avatar
If you have a vacume advance, that is responsible for your part throttle advance. Get an adjustable vacume advance, and dial it in for latter advance. Then you still have the same full throttle power from your static/mechanical advance with none of the pinging at part throttle.
________
________
Old 01-29-2007, 09:45 AM
STEVE POTTS's Avatar
Cobra Make, Engine: Midstates, 427FE stroked to 482CI
Why cant somebody make a 5th gear ratio somewhere in the 0.75 for the tko600's. Give the market what it wants.
Old 01-29-2007, 10:18 AM
Poolw's Avatar
Cobra Make, Engine: SPF, KC 427
Get a 6 speed and drive it 5th.
To my Cobra: - - when I'm with you - Oboy!
Old 01-30-2007, 05:29 PM
Given the popularity of the TKO600 right now, you might want to try to sell your old one locally and buy new with the correct ratio. The total cost of replacement might be equal to or less than the $500 difference and you won't have to open it up. Do you have an active Craigslist in your area?
Just a thought...
Old 01-30-2007, 07:45 PM
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
Originally Posted by SPF1061
Mike -
-Steve
Dito - went to .82 trans with 3.25 - perfect for a high HP/TQ motor
Old 03-12-2007, 11:21 AM
Mike, did you ever swap 5th gears or did you sell the old tranny and get a new one? If you did swap 5th gears, then what did you pay someone for the labor to do so?
Old 03-12-2007, 12:25 PM
RodKnock,
I spoke with Jim at Standard Transmissions and he said it would be pretty costly to do the swap. The entire tranny needs to be gutted to get to the 5th gear. Also a fair amount of parts are needed as well. Jim statedIt probably makes more sense to buy another tranny.
Old 03-12-2007, 12:37 PM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Mike, I have the same transmission with my 482. I like cruising along a 1700 rpm in 5th gear at 70mph. You can actually talk to a passenger or think without a lot of noise (except for wind).
Dave
Old 03-12-2007, 12:47 PM
Dave,
I do like the 1700-1800 crusing at 70mph but my motor doesn't. It will ping at the slightest incline. Then downshifting to 4th at 70 I'm at 3200 rpms. Not a good alternative either. I am about done rebuilding my motor maybe it will be better? If not I guess at some point I'll get the correct OD with either a new trans or new th gear.
Old 03-12-2007, 01:23 PM
Thanks, Mike. I kinda thought that would be the answer. My trusty old speadsheet says that with a 3.31 final drive ratio, the RPM's at 70 mph would be roughly 1,900 rpms with the 0.64 and 2,450 rpm with the 0.82. From personal experience, I think 1,900 is low and the CHP may not like 2,000-2,200 rpm.
Old 03-12-2007, 04:30 PM
jwd's Avatar
jwd jwd is offline
This combo gives you a usable 1st gear AND 5th gear. I drove every combination of trans. and rear gears before deciding on this one.
