SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 08-24-2007, 06:41 AM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Shifting without the clutch
Transmission experts, any downside during casual driving to shifting under no load without using the clutch? I have done it for years on various cars and trucks and never had a problem, in fact got 100K miles on the clutch of my 94 GT Mustang. Took a friend of mine for a ride in my Cobra and he freaked out when I did this?
Old 08-24-2007, 07:15 AM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
I have been shifting without the clutch for a many years, it started with my 440 Challenger after the clutch pedal dropped to the floor right after a hard run through the gears.....I just had to turn the car off at the stop lights and start it in first gear to take off.....once I became proficient at it I continue with my 01 GT Mustang 84K miles. It is funny the looks and comments you get from passengers when they realize your not using the clutch. Upshift and downshift..it's fun, although im sure the syncro rings don't like it
Old 08-24-2007, 07:20 AM
Jimi G's Avatar
As long as you know what you are doing it will not effect the clutch. The only down side is that it can cause extra stress on the sycros, but there again if you know what you are doing and have the engine at the proper rpms then you will not do any damage. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 08-24-2007, 07:29 AM
jams's Avatar
Cobra Make, Engine: B & B
I have done it for years as well. As long as it is done right. Matching seed with rpm everything works well.
To entertain myself during my college commute, I would see if I could make it from home to college with out the clutch. I actually did it once. I had a Chevy pickup with an extra low gear. Rolled out of my parking spot to start and put it in gear and rolled it right into a parking space.
I have noticed it doesn't work as well with a new-tight trans. I waited about 2k on my cobra tremac.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 08-24-2007, 01:30 PM
Murphy's Avatar
That's what I thought. Thanks
