SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 10-04-2007, 08:52 PM
Cobra Make, Engine: NAF cobra, 427, 2x4's, 550 h.p.
Default Rebuilding Toploader, Need Help!!!
Hey Guys, I Have A Top Loader 4 Speed. How Can I Tell What Year It Is ? Also Can You Tell Me The Best Place To Get The Parts I Need To Overhaul It? I Recently Put New Brake And Clutch Master Cylinders In My Naf Cobra. Since , I Am Having A Gear Grinding Problem. I Have Blead The System A Couple Of Times And It Looks Like The Slave Cylinder Is Engaging The Clutch All The Way, But Unless I Double Clutch, After Starting The Car, I Grind Going Into Reverse And It Is A Problem Down Shifting Most Times If I Don't Double Clutch It. I'm Thinking The Syncro's Are Bad And Maybe It's Time For A Rebuild. Any Suggestions? Thanks
Tchrome
LIFE'S JOURNEY IS NOT TO ARRIVE AT THE GRAVE SAFELY IN A WELL PRESERVED BODY,BUT RATHER TO SKID IN SIDEWAYS, TOTALY WORN OUT...SCREAMING, "HOLY ****" WHAT A RIDE!"
