03-20-2009, 08:08 PM
Ma
Hi Bob,
The 3550-TKO is a 5-speed overdrive. The TKO-600 has an optional .82 overdrive that will work very nice. Your 3550 has the .68 overdrive and has the same gear ratio as the TKO-500. Both the TKO-500 & TKO-600 are direct bolt in with a change of a driveshaft yoke and the TKO-600 will need a 26-spline clutch disc.
The 6-speed is a T-56 and has 2 overdriven gears. It comes with a SB Ford bellhousing and will require a new yoke, and shorten the driveshaft.
As a Tremec Elite distributor I stock all models of the TKO-500 & TKO-600 and the T-56. I am also a service center for retail Tremec dealers, garages and end uses.
Call me will any questions. I'm offering free shipping and you would be tax free being an out of state sale.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
