Go Back   Club Cobra > Club Forums > Tri State Cobra Association
January 2025
26 27 28 29 30 31
Old 06-14-2006, 08:49 PM
Default What should I do?
I was out of the country for while and haven't turned over the engine in my cobra since last October I have a 351w with a mild performance cam and gt40p alum. heads! Should I squirt a few drops of oil or fuel additive inside the cylinders before turnning it over? Or will just changing the oil do the trick? Not sure what to do? I wish I had someone drive it periododicly while I was away but didn't and now I want to fire it up but afraid it will damage my engine? Any ideas would be super!
http://66cobra.0catch.com
Old 06-14-2006, 08:54 PM
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
Change the fuel or add some fuel additive, change oil and filter. Pull distributor and use a drill and priming tool. Run drill till you have oil pressure. Install distributor, start her up, check timing and let warm - drive it.
Old 06-14-2006, 09:07 PM
Ibr8k4vetts's Avatar
If it was mine I would start it up and take it for a nice little drive and if everything is running fine I would just change the oil and filter
Mike Z
HTML code is On
