Turn Ten Racing, Inc. and D&D Cobra of Quebec
Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Turn Ten Racing and D&D Cobra
User Name
Password
Club Cobra Home Register FAQ Members List Calendar Today's Posts
January 2025
26 27 28 29 30 31
Old 10-21-2008, 05:01 PM
ddcobra's Avatar
Thumbs up For US Customer best price ever !!!
Best price ever 24500 CAN = 20500 US (exange rate)
The EVO5 bird cage alu. floor Complete kit gives you everything you need to build your car
Frame:
Complete jig-welded original style 4” round tube frame. Includes all mounts ready to accept small or big block Ford .
Comes powdercoated in gloss black and silver suspensions parts
Includes three point SS roll bar
Includes mounts to accept passenger side roll bar.
Body:***INSTALL***
Hand laid 3/16” laminate composite body and panels made with vinylester resin. COMPLET BODY DOOR,TRUNK,HOOD WITH HINGES.
Complete Front Suspension:***INSTALL***
Unequal length a-arm control arms with QA1 coil-over shock suspension.
500lb. black powdercoated performance springs
Adjustable upper control arms with ball joints
Lower tubular control arms with ball joints
Complete Rear Suspension:***INSTALL***
High-end IRS deluxe rear suspension with QA1 coil-over and Ford 8.8” 3.08 gears.
Complete Front/Rear Brake Kit:***INSTALL***
S/N 95 style spindles and spindle adapter bracket
Front Brakes, Ford 11” front rotors w/calipers, brake pads
Rear Brakes, Ford 10.5” rear rotors w/calipers, brake pads, slider and caliper axle mount brackets.
Russell stainless braided brake line, front and rear w/mount clips, banjo bolts and brake line mounting fasteners
Pre-flared 3/16” brake line and brake line T-adapter
Lokar emergency brake handle, fasteners and cable
Complete Steering System:***INSTALL***
Bump steer kit
15:1 Manual steering rack w/inner and outer tie rod ends
Polyurethane steering rack bushings
Steering rack shaft adapter 9/16-26 spline
Flamming river steering columb and shaft
14” Vintage wood and aluminum steering wheel
Complete Fuel System/Parts:
Aluminium fuel tank
3/8 Fuel lines, connectors and filter
140GPH black fuel pump
Cooling System/Parts:
16''Electric cooling fan
28''x19''Aluminum radiator
Engine Accessories/Side Exhaust/Mounts:
Engine/Transmission mounts (select 302/351 or 4.6L, or 390/427/428, or 429/460)
Exhaust and headers,(select 302/351 or 4.6L, or 390/427/428, or 429/460),
Gauges and Dash and Electrical Assembly:
427 style aluminum dashboard
Padded dash cover, black vinyl
EZ wiring harness
headlight switch, 3-position turn signal switch
Dash indicators, Red, Green, Blue dash lights
Complete set of 7 Autometer cobra gauges, w/connectors, terminals and installation kit. Includes the following gauges:
Speedometer
Tachometer
Oil Pressure Gauge
Water Temperature Gauge
Fuel Level Gauge
Voltmeter
Oil Temperature Gauge
Complete Interior Accessories:
Authentic 427 roadster seats, black vinyl w/fasteners
5-point harnesses. 3” wide driver and passenger, frame mounted
Complete cockpit carpet set, black all-weather
Lokar Emergency brake boot, black vinyl
Authentic interior rear view mirror w/fasteners
Original style door latches,
Authentic 14” wood and aluminum steering wheel
Exterior Accessories and Lighting:
Wiper kit
Authentic Chrome-on-Brass vintage windscreen, tinted with side bars and fasteners. DOT safety glass compliant
Authentic 427 three-lock set including T-trunk handle, L-shaped hood handles, cam wedges
Authentic 3.5” gas cap, polished cast aluminum
side louvers.
cobra badging nose and tail
Original style headlamp assemblies, including buckets,headlamps, trim rings, and fasteners (DOT approved).
Original style British front amber turn signals, and red rear tail-lights
All lighting is DOT approved.
Complete Pedal Box and Components:
Tilton triple padal and master cylinders
2 x 5/8 Master Cylinders
1 x 3/4 Master Cylinder
Price: 24500$ CAN. = 20500 US
Old 10-21-2008, 05:12 PM
Cobra Make & Engine: 302 Fuel Injected
Great posting but I don't have a clue who you are or how to get to your site.
Duhhhh!
Building my 5th Cobra, one day I will know what I am doing!
Old 10-21-2008, 05:13 PM
Cobra Make & Engine: Scratch built CSX style frame, Carbon fiber body, 393 Stroker, T-bird IRS, T5
ddcobra.com
Old 10-21-2008, 05:16 PM
I found it...great website, I can see you spent a lot of time on it.
Duhhhh!
I would be interested, but all I see is...well nothing.
How can you hope to do business with that three page web site.
Old 10-21-2008, 05:21 PM
danc30's Avatar
Cobra Make & Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Ditto what Marky said.
Old 10-21-2008, 05:23 PM
I mean, for that why even bother typing and wasting all of our times.
Believe me when I say I would like an alternative to FFR, but that post and web site is not worth the effort.
Old 10-21-2008, 05:28 PM
ddcobra's Avatar
Take a look on our forum on cc link is you will see what you get Turnkey built from A to Z!!
Old 10-21-2008, 05:34 PM
Thats good, I could be interested, but your web site is crap and it really isn't that difficult to have a professional web site is it??
There is no mention of US certificates of origin etc. etc.
Old 10-21-2008, 05:41 PM
ddcobra's Avatar
Most of my sale is in europe it why i do not want to have a web site with pricing and discription (europe not to same pakage than Us or Canada) yes it will come with a certificates of origin
Thanks
Old 10-21-2008, 05:42 PM
mickmate's Avatar
Cobra Make & Engine: CSX 4772 old iron FE
If you're more worried about the website than the car you have no idea what to look for. The quality of work and high end components going into this thing are pretty apparent. If it was me I'd get my arse off the internet and go and find one to look at.
mickmate
http://www.actoncustom.com/
Old 10-21-2008, 05:51 PM
I am more worried about the possibility of never being able to register one. I know what I am looking at having built 6 cobras.
But, the US vendor has gone and the web site is none existant and there is no forther information published.
I am not prepared to drive to Canada on a whim.
Hey...Thanks for your input guy in NH.
Old 10-21-2008, 06:01 PM
Jamo's Avatar
Super Moderator
I contributed to CC in 2006
I have in the past contributed to CC
Cobra Make & Engine: KMP 184/482ci Shelby
Marky...cool it.
Thank you for your expected cooperation.
Jamo
Old 10-21-2008, 06:09 PM
Senile Club Cobra Member
Cobra Make & Engine: Superformance
Talking
"Costumer"???
I already have my Halloween costume.......I'm either going as Carroll Shelby (big roll of dollars chasing a penny") or as Jamo (big set of cheeks.......never mind, I don't want to be banned...........)
rick@autoventureusa.net
Old 10-21-2008, 06:10 PM
ddcobra's Avatar
Mike from Turnten stop to import our Cobra because the exchange was not to good, the Canadian money was to strong now you guys have the avantage you save 18% from our retail only in exchange!!!!
Thanks Don,
Old 10-21-2008, 06:12 PM
Oh, oh......................soon a barrister will knocking upon your door...........
ddcobra's Avatar
"Costumer"???
Sorry,
I think i have made some mistakes
Don,
Old 10-21-2008, 06:33 PM
hey marky.... you seem real pissy whats the matter? if it is not to your liking move on and stop stinking up the place, no ones forcing you to buy from this guy, oh wait he is going to revamp his whole web site just for you, you dont like it go buy a factory five. and quit your complaining
Old 10-21-2008, 06:40 PM
I could well be interested. a good web site would help.
You are 5 hours from me.
I have just sold my FFR and like what I see but the details are so sketchy.
How would importation work?
If Picked up can it be brought over the border??
Old 10-21-2008, 06:41 PM
Cobra Make & Engine: DD cobra roller ;body ??
i have to agree with COBRAS
these days you see a lot of web sites no products
DD has a lot of good product and less web site
all you need to see is here on CLUB COBRAS
Old 10-21-2008, 06:47 PM
ddcobra's Avatar
To compare our kit (how the price is good) to the big guys of MA
The kit we offer have more parts than the competition . If we compare what you receved from us you will need to buy more options to match our kit.
Our kit............vs...........Competition........... ...Option
20500$..............................19900$
N/C...................................120$.......... .....Body cut off
N/C..................................2999$.......... .....I.R.S
N/C....................................125$......... ......Wind wings
N/C....................................125$......... ......Sun viser
N/C...................................290$.......... ......Chrome roll bar
N/C...................................695$.......... ......S.S bumper
20500$..........vs..................24254$
Thans Don,
