Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 05-11-2012, 06:18 AM
*13*'s Avatar
Sounds like you're headed in the right direction
ERA FIA 2088
  #22 (permalink)
Old 05-12-2012, 02:57 PM
Gaz64's Avatar
Originally Posted by TonyLoz View Post
I finally got out to my garage last night wth my float gauges from Gene Berg. All four carbs where set quite high. What a difference... The idle changed from about 900 RPM to 1300 RPM and the engine behaved very well around town. Now I have stumbles at higher RPM. I starts to act up around 3500 RPM and seems to carry on up to 5000 RPM where I shift. Its a new motor so I havent been running it up to 6000RPM (yet). I am thinking a main jet change may fix this??
Gaining on it
Tony Loz
Tony,
I'd up the venturi size first, 37 is a bit small for a 408, you need at least 40mm.
Gary
  #23 (permalink)
Old 05-15-2012, 11:13 AM
Cobra Make, Engine: PPMC Body on a modified Midstates chassis, weber fed 408
Thanks Gary,
I trust things are good in Brisbane, I was visiting several years ago on business. Used the Watercats to get around (visiting the pubs).. You have good beer down there...
The other day my wife was asking what I was going to do now that my Cobra is "done", my response was simple. Its not done, I have Webers.... I will look into uping the venturis but I have it running pretty well right now. I have an LM1, plan on hooking things up this weekend, gather some data and see where I am at. Make adjustments from there.
Again, thank you all for your suggestions
Tony Loz
