Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
January 2025
26 27 28 29 30 31
Old 07-23-2013, 08:12 PM
Cobra Make, Engine: FF 302 cam,balanced,48 IDA Webers
Default Needle Valves
Anyone have any dealings with a D&G Valve Co, in Mass.? I came across an old print- out from the web suggesting they make a better needle valve for the 48IDAs. Supposed to maintain better control with any fuel pressure flux. Jon
Old 07-23-2013, 11:52 PM
Rick Parker's Avatar
They are gone. The propritor died and so did the idea.
Rick
Old 07-24-2013, 06:29 AM
Thanks Rick, Must have been an old article. Regards, Jon
Old 07-25-2013, 06:26 PM
Eljaro's Avatar
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
I have a set of those valves. They feature a glass ball as the closing object instead of a needle valve.
Installed them once and flooded two carburetors
Put them away to test them some other time. Still waiting.
Nothing sounds better than a Cobra in a Tunnel !
Old 07-26-2013, 02:25 AM
Gaz64's Avatar
They have been around for a while.
Gene Berg may still have them:
Gene Berg Enterprises
Gary
Old 07-27-2013, 10:20 AM
Just a word of caution on these repops. The opening at 3.3 mm is quite large and goes against the suggestion of using the smallest opening that will provide enough fuel. This large size makes it difficult to control fuel level accurately. These are sized for large CID air cooled drag race VW applications where they are commonly used because of the severe vibration.
Rick
