Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
November 2024
  #21 (permalink)
Old 12-15-2013, 05:47 PM
Cobra Make, Engine: Contemporary Cobra
Default 40 chokes
Thanks, found it and looking for some 40 chokes
Jon
  #22 (permalink)
Old 12-15-2013, 08:12 PM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Jon:
Would you please post the jets, air correctors, pump jet and bypass and E tube you are presently using ? If yours is running great, why change ?
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
  #23 (permalink)
Old 12-15-2013, 08:26 PM
Default Ok
It's running really nice and I would like to hook up a ARI gauge to confirm that it is correct. I would also like to try 40 chokes....
Chokes 45
Idle jet 65
Idle jet holder 110
Etubes f11
Main jet 170
air corrector 175
Timing 18 int and 38 total
Always room for some improvement
  #24 (permalink)
Old 12-15-2013, 08:40 PM
MOTORHEAD's Avatar
Jon:
Amazing! I just drilled my idle holders to 1.10 today ! still too rich with the 70 jets, going back to the 65's tomorrow.
e tubes f11
main jet 180
ac 180
pump jet(shooter) .50
pump bypass .50
timing 22, 38 total
I have a afr gauge in the port pipe, going to move it to the stbd side as a doublr check,as that side seems to be running leaner.
Ted
  #25 (permalink)
Old 12-15-2013, 08:45 PM
Default Ted
Ted, your a sailor?
What is your CI?
Jon
  #26 (permalink)
Old 12-15-2013, 10:16 PM
MOTORHEAD's Avatar
Sailor, no. Boater and pilot, yes. Port and starboard eliminate the "as viewed from front or back ?" confusion when using "left" or "right." But if you must know which is port and which is starboard.
My engine is 454c.i.
Ted
  #27 (permalink)
Old 12-16-2013, 10:13 AM
Cobra Make, Engine: spf 2112 *427 stroker windsor
Ted and Jon
I like both your settings
Ted yes try the 40 chokes, im sure you will like.
Are either of yous experiancing any flat spoting when punching it between idle and main transition curcuit?
Carmine
  #28 (permalink)
Old 12-16-2013, 10:53 AM
MOTORHEAD's Avatar
Carmine:
Yes on the "flat spot" when punching it. AFR gauge shows mixture goes lean. 15-17 then off scale. My biggest problem after the oil fouling plugs.
Ted
  #29 (permalink)
Old 12-16-2013, 11:09 AM
Ted
That's what I expected.
Larger idle jet with larger air corrector will cure that.
Within sizes I posted earlier.
Your idle mixture screws would be 1 to 1 1/8 turn open from lightly seated closed position.
Your idle when hot should be min 900 - 1000 rpm
Carmine
  #30 (permalink)
Old 12-16-2013, 11:39 AM
I idle at 850 rpm and launch around 1200 rpm, in 1st w/1200 launch it will pull to 7000 which is over the top....pulls so fast and I should be shifting at 6400 all power is in @ 6000.
I had thought about going smaller on chokes..40's
Jon
  #31 (permalink)
Old 12-16-2013, 12:33 PM
Hey Jon
If it's running that good why do you want 40 chokes?
Carmine
  #32 (permalink)
Old 12-16-2013, 02:52 PM
MOTORHEAD's Avatar
Carmine & Jon:
Swapped out the 45 chokes for the 40's. Whoa Nellie! It goes now!!!! No flat spot, just jumps ahead when you punch it ! Made no other changes, but still need to tweak other areas.
I probably could have made the 45's work with your continued help, but they probably would have only made a difference at the top end, where this engine won't spend much time, due to no place near here to turn her loose !
  #33 (permalink)
Old 12-16-2013, 08:25 PM
Default 45chokes
Always room for improvement and after reading Motorheads comments I will be trying them this weekend!
Jon
  #34 (permalink)
Old 12-16-2013, 08:47 PM
Good to hear Ted
Keep the progress going
Another adage to strength in numbers when problem solving
Carmine
  #35 (permalink)
Old 12-31-2013, 06:06 AM
Default 40 Chokes
I swapped out the 45 chokes for 40's over the weekend and what a difference.
The transion is so smooth, no hesitation at all in cruising range. I doesn't pull as strong on the top, it pulls strong to 5700 where it would pull to 7k with the 45's..... jetting is still the same as when I used the 45's. I'm going to make a change to the main jet or air corrector, that should help.
Happy NY to All
Jon
