Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
January 2025
26 27 28 29 30 31
Old 10-05-2008, 01:12 PM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Weber IDA AN Fitting
I recall seeing a setup with AN fittings on a IDA installed on a BB. The carb bodies are facing in and have enough clearance for the AN fittings.
I have tried buying AN fittings to do just that but had clearance issues.
Does anyone know were I can purchase these fittings to do the exact same thing?
Or what are you guys using for fuel connections for the IDA.
If you can post pictures that would be helpful.
Thanks
Old 10-05-2008, 03:49 PM
ENTDOC's Avatar
here is my 427, I had the stainless hard lines made and used A?N fittings on the aluminum fuel blocks, Pierce manifolds has these.
Old 10-05-2008, 03:51 PM
ENTDOC's Avatar
here is the 302 using AN fittings and startlite hose
Old 10-05-2008, 05:26 PM
Cobra Make, Engine: Building Mk4 Sold - Factory Five Mk. 3.1
Wink
As mentioned above, Startlite is a great choice. It's made by Aeroquip (Eaton) and looks as good as you could ask for (Just look at the above photos).
Old 10-05-2008, 05:32 PM
ENTDOC's Avatar
I try to use Startlite every where I can, it just looks right and is much easier to work with than stainless braid
